Dayananda Posted November 8, 2020 Share Posted November 8, 2020 This is the text I found in my cad Drawing 2T16 - 05 I need to remove the blank space which after 16 and before 05 The minus mark is ok. New texts should be as 2T16-05 Pl can you help. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 8, 2020 Share Posted November 8, 2020 (while (vl-string-search " " str) (setq str (vl-string-subst "" " " str))) where str is the string you want to change 1 Quote Link to comment Share on other sites More sharing options...
Trudy Posted November 8, 2020 Share Posted November 8, 2020 Something from me, it can be change for multiple text. (defun c:try1 (/ sel text text2 ) (setq sel (car (entsel "\nSelect some text: "))) (setq text (cdr (assoc 1 (entget sel)))) (setq text2 (vl-list->string (vl-remove 32 (vl-string->list text)))) (entmod (subst (cons 1 text2) (assoc 1 (entget sel)) (entget sel))) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
