Jebster Posted November 5, 2020 Share Posted November 5, 2020 How do you install hatch patterns in LT? I can't seem to find a folder where they should be inserted. Thanks, Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 5, 2020 Share Posted November 5, 2020 You can save them anywhere. In Autocad, open up "Options", go to the "Files" tab and add a new "Support File Search Path" that points to the folder where your hatch patterns are saved. Quote Link to comment Share on other sites More sharing options...
Jebster Posted November 6, 2020 Author Share Posted November 6, 2020 Thank you CAD64. I am still having difficulty. I am not sure how to access the Autocad "options" and "files" tabs. I don't see an options tab anywhere. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 6, 2020 Share Posted November 6, 2020 Just type OPTIONS at the command prompt. You can also right click anywhere on screen and choose "Options" from the pop up menu. Quote Link to comment Share on other sites More sharing options...
Jebster Posted November 6, 2020 Author Share Posted November 6, 2020 I am there. How do I add a "support file search path"? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 6, 2020 Share Posted November 6, 2020 See here: https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoCAD-LT/files/GUID-348D791E-D621-444F-B059-C0C6F97AD69F-htm.html Quote Link to comment Share on other sites More sharing options...
