rcb007 Posted November 4, 2020 Share Posted November 4, 2020 I have a block that has 3 attributes. One for Half, Full and double are the tag names. Im tryin to create a field link to a viewport custom scale which can take the field and place the value (either half or double) into the attributes. I found this which works for the full scale value. I am wondering how to get the lisp to either add the half of the full value and double of the full value. thank you for your help. (defun c:scale (/ vpObj fldObj vpID util fldtxt) (vl-load-com) (setq vpObj (vlax-ename->vla-object (car (nentsel "\nSelect the viewport: ")) ) fldObj (vlax-ename->vla-object (car (nentsel "\nSelect the Full Attribute Block: "))) vpID (vla-get-objectid vpObj) ) (if (> (vl-string-search "x64" (getvar "platform")) 0) (progn (setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)) ) vpID (vlax-invoke-method util "GetObjectIdString" vpObj :vlax-False ) ) ) (setq vpID (vl-princ-to-string (vla-get-Objectid vpObj))) ) (setq fldtxt (strcat "%<\\AcObjProp Object(%<\\_ObjId " vpID ">%).CustomScale \\f \"%lu2%ct1%ps\%qf2816\">%" ) ) (vla-put-textstring fldObj fldtxt) (vla-update fldObj) (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 1 ) (princ)) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 4, 2020 Share Posted November 4, 2020 Use a formula field, e.g. for double: "%<\\AcExpr (2*%<\\AcObjProp Object(%<\\_ObjId " vpID ">%).CustomScale>%) \\f \"%lu2\">%" Quote Link to comment Share on other sites More sharing options...
rcb007 Posted November 4, 2020 Author Share Posted November 4, 2020 Thanks for the response back! I went deeper with the routine trying to utilize your LM:Setattributevalues. Either im close, or way the wrong direction. Command: test Select the viewport: Select Block: Unknown command "0". Press F1 for help. ; error: bad function: #<VLA-OBJECT IAcadAttributeReference 000001c3abeb6e88> (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:test (/ vpObj fldObj vpID util fldtxt fldtxthalf fldtxtDouble) (vl-load-com) (setq vpObj (vlax-ename->vla-object (car (nentsel "\nSelect the viewport: ")) ) fldObj (vlax-ename->vla-object (car (nentsel "\nSelect Block: "))) vpID (vla-get-objectid vpObj) ) (if (> (vl-string-search "x64" (getvar "platform")) 0) (progn (setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)) ) vpID (vlax-invoke-method util "GetObjectIdString" vpObj :vlax-False ) ) ) (setq vpID (vl-princ-to-string (vla-get-Objectid vpObj))) ) ;;CustomScale Forumlas (setq fldtxthalf (strcat "%<\\AcExpr (0.5*%<\\AcObjProp Object(%<\\_ObjId " vpID ">%).CustomScale>%) \\f \"%lu2\">%")) (setq fldtxt (strcat "%<\\AcExpr (1*%<\\AcObjProp Object(%<\\_ObjId " vpID ">%).CustomScale>%) \\f \"%lu2\">%")) (setq fldtxtdouble (strcat "%<\\AcExpr (2*%<\\AcObjProp Object(%<\\_ObjId " vpID ">%).CustomScale>%) \\f \"%lu2\">%")) ;;Field Text to Attributes (progn (setvar 'attreq 0) (command "insert" "test" p scl scl "0") (setq b (vlax-ename->vla-object (entlast))) ( lm:vl-setattributevalue b "half" (fldObj fldtxthalf)) ( lm:vl-setattributevalue b "full" (strcat (fldObj fldtxt))) ( lm:vl-setattributevalue b "double" (strcat (fldObj fldtxtDouble) 2 2)) (setvar 'attreq 1) ) ;; (vla-put-textstring fldObj fldtxt) (vla-update fldObj) (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 1 ) (princ)) BAR.dwg Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 4, 2020 Share Posted November 4, 2020 (edited) @rcb007 ;; Change this (lm:vl-setattributevalue b "half" (fldobj fldtxthalf)) (lm:vl-setattributevalue b "full" (strcat (fldobj fldtxt))) (lm:vl-setattributevalue b "double" (strcat (fldobj fldtxtdouble) 2 2)) ;; To this (progn ;; (setvar 'attreq 0) ;;(command "insert" "test" scl scl "0") ;;(setq b (vlax-ename->vla-object (entlast))) (lm:vl-setattributevalue fldobj "half" fldtxthalf) (lm:vl-setattributevalue fldobj "full" fldtxt) (lm:vl-setattributevalue fldobj "double" fldtxtdouble) ;; (setvar 'attreq 1) ) Depending on your version of CAD you can use setpropertyvalue as well. (setpropertyvalue (entlast) "half" fldtxthalf) And you don't have your insertion point 'p' or scale 'scl' defined for a block .. although you select a block at the top? (command "insert" "test" p scl scl "0") There are many more errors and I'm done chasing them... Edited November 4, 2020 by ronjonp Quote Link to comment Share on other sites More sharing options...
rcb007 Posted November 4, 2020 Author Share Posted November 4, 2020 Wow. Thank you. Would the LM-Setattributevaule still be able to work through a dynamic block? I know the block I showed was a normal block. I wanted to know what would need to be changed if any, for it to work. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 4, 2020 Share Posted November 4, 2020 (edited) See if this sheds any light: (defun c:test (/ fldobj util vpid vpobj) (if (and (setq vpobj (car (entsel "\nPick viewport: "))) ;; Add a check that it's a viewport selected (setq fldobj (car (entsel "\nSelect Block: "))) ;; Add a check that it's your barscale selected (setq vpid (vla-get-objectid (setq vpobj (vlax-ename->vla-object vpobj)))) ) (progn (if (> (vl-string-search "x64" (getvar "platform")) 0) (progn (setq util (vla-get-utility (vla-get-activedocument (vlax-get-acad-object))) vpid (vlax-invoke-method util "GetObjectIdString" vpobj :vlax-false) ) ) (setq vpid (vl-princ-to-string (vla-get-objectid vpobj))) ) (foreach a '("half" "full" "double") (setpropertyvalue fldobj a (strcat "%<\\AcExpr (" (cond ((= a "half") "0.5") ((= a "full") "1.") ((= a "double") "2.") ) "*%<\\AcObjProp Object(%<\\_ObjId " vpid ">%).CustomScale>%) \\f \"%lu2\">%" ) ) ) (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 1) ) ) (princ) ) (vl-load-com) Edited November 4, 2020 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
rcb007 Posted November 4, 2020 Author Share Posted November 4, 2020 Thank you again ronjonp. I do see it. Way a lot cleaner and to use the setpropertyvalue variable. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 4, 2020 Share Posted November 4, 2020 3 minutes ago, rcb007 said: Thank you again ronjonp. I do see it. Way a lot cleaner and to use the setpropertyvalue variable. Quote Link to comment Share on other sites More sharing options...
rcb007 Posted November 10, 2020 Author Share Posted November 10, 2020 I am not sure if I am missing something or not, this routine works awesome with an mview and selected block. I just tried to use it with a irregular rectangle. I am not sure how to change the field so that it would select either or. I thought a mview was a mview even if it was a polyline type viewport. thanks Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 10, 2020 Share Posted November 10, 2020 Use something like this: (defun _getviewport (e) (if e (cond ((= "VIEWPORT" (cdr (assoc 0 (entget e)))) e) ((cdadr (member '(102 . "{ACAD_REACTORS") (entget e)))) ) ) ) ;; (_getviewport (car (entsel "\nPick a viewport: "))) Quote Link to comment Share on other sites More sharing options...
rcb007 Posted November 10, 2020 Author Share Posted November 10, 2020 Got it! Adjust the code and it works. Thank you once again! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 10, 2020 Share Posted November 10, 2020 4 minutes ago, rcb007 said: Got it! Adjust the code and it works. Thank you once again! Quote Link to comment Share on other sites More sharing options...
