Guest Posted November 2, 2020 Share Posted November 2, 2020 Hi i am using slides for my image menus. I have slides 1kb (and load fast ) , but i have some slides 777 kb - 128 kb and load too slow. How can compress the size of this slides ? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted November 2, 2020 Share Posted November 2, 2020 any ideas Quote Link to comment Share on other sites More sharing options...
RobDraw Posted November 2, 2020 Share Posted November 2, 2020 Sure, but not with AutoCAD. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 2, 2020 Share Posted November 2, 2020 (edited) Can you tell me another program? I want to ask if is some recommended dimensions for slide Thanks Edited November 2, 2020 by prodromosm Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 2, 2020 Share Posted November 2, 2020 This may reduce, not sure if mslide is pixel set like 200 dpi or uses screen resolution, a quick test lower your screen res and make the 777kb slide and see if smaller, 4k screens comes to mind. Again not sure, have you looked at what is in the slides in terms of content we had some STD dwgs but erase turned off layers a heap of stuff then made slide. Really did not need dims displayed in slide. Made a rectang, hatch ansi31, scale 5 = <1kb scale 0.1 = 9kb so hatching has big impact. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 3, 2020 Share Posted November 3, 2020 The best way to make slice is through viewport . I make a small viewport ,in the layout and i make a slide through viewport in model space. The results was max 1 - 16 kb. Thanks for the help Quote Link to comment Share on other sites More sharing options...
