(defun c:rb ( / ss ang ) (vl-load-com)
 (setq ss (vlax-ename->vla-object (car (entsel "\nSelect Block to Rotate: "))))
(setq ang (getangle "\nSpecify Rotation Angle: "))
  (vla-put-Rotation ss ang)
)(princ)
I Frankenstien-ed this lisp routine from different posts around the web, and while it works "perfectly" I hate that it doesn't know that something is selected or if I start the command with something selected it will ask me to select it again, it stays selected after the command is done.
I've used other rotate block lisps routines out there, but after the initial run, if I do it again, they seem to add to it's current rotation angle. i.e. if the block is at 23 deg, and you select an angle that is 10 deg, the block will then go to 33 deg. Others would just be completely weird
Improvements I would like to implement, but not good enough implement myself:
work on multiple blocks
move to angle prompt if blocks are already selected selected
if I select nothing or wrong object prompt to retry. If possible, if a mix of blocks and other objects are selected, filter out other entities.
Thanks ahead of time. I can live with the current setup, but any improvements are always welcomed.
Why do you need code to do this? Filter your blocks then change the rotation in the properties palette.
Simple example for filter.
(defun c:foo (/ s)
  (if (setq s (ssget ":L" '((0 . "INSERT"))))
    (progn (sssetfirst nil s) (vl-cmdf "_.properties"))
(defun c:foo (/ s)
I won't be able to click on two points along a line with the property palette.
I can take a distance, copy the rotation value, select the objects, open properties, paste the rotation value hit enter. That's a long way.
avoiding all those steps is what I was trying to do.
Fair enough .. try this:
(defun c:foo (/ a s)
  (if (and (setq a (getangle)) (setq s (ssget ":L" '((0 . "INSERT")))))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (vla-put-rotation (vlax-ename->vla-object e) a)
wow! worked great!
added a prompt for rotation angle.
(defun c:rb (/ a s)
  (if (and (setq a (getangle "\nSpecify Rotation Angle: ")) (setq s (ssget ":L" '((0 . "INSERT")))))
You guys make it seem so easy!
