Ber Posted October 30, 2020 Posted October 30, 2020 Hello to all this Community. My goal is to transfer a script/lisp batch from AutoCAD to BricsCAD V20. In AutoCAD, we use -IMAGE D * command. This command do not exist in BricsCAD. I am looking for a another command or a lisp to detach all the images in our DWG. Thank you for all the help you will give to me. Quote
BIGAL Posted October 30, 2020 Posted October 30, 2020 Join the Bricsys forum found this it may be what you want https://forum.bricsys.com/discussion/10295/detach-image-with-lisp Quote
dan20047 Posted January 5, 2021 Posted January 5, 2021 Lisp here detaches images that don't exist in the drawing, could probably be easily adapted https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/detach-images-not-found/td-p/9050785 -Dan Quote
