mousho Posted October 29, 2020 Share Posted October 29, 2020 hello; i use this the cide above to select dimension (ssget "x" (list (cons 0 "Dimension"))) now i need a code to select only Rotated Dimension Only any Idea??? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted October 29, 2020 Share Posted October 29, 2020 Read the comments in the routine for more info. (if (setq ss (ssget "_X" '((0 . "*DIMENSION")))) (repeat (setq in (sslength ss)) (setq ent (entget (ssname ss (setq in (1- in))))) (if (member '(100 . "AcDbRotatedDimension") ent) ;; if this GC is existed among DXF codes then its Rotated Dim. (progn ;; run your stuff here .... ) ) ) ) 1 Quote Link to comment Share on other sites More sharing options...
mousho Posted October 29, 2020 Author Share Posted October 29, 2020 (edited) THX But its not working maybe u can help me to understand with what i am replacing ss in the command line (defun c:DIMR ( / ss textString) (vl-load-com) (if (setq ss (ssget "_X" '((0 . "*DIMENSION")))) (repeat (setq in (sslength ss)) (setq ent (entget (ssname ss (setq in (1- in))))) (if (member '(100 . "AcDbRotatedDimension") ent) ;; if this GC is existed among DXF codes then its Rotated Dim. (progn (command "-DIMstyle" "A" ss "" ; what i need to write instead ss here ) ;; run your stuff here .... ) ) ) ) (princ) ) Edited October 29, 2020 by mousho Quote Link to comment Share on other sites More sharing options...
Tharwat Posted October 29, 2020 Share Posted October 29, 2020 It is selecting dimensions but it would filter all none rotated dimensions out. How did you complete the routine? Quote Link to comment Share on other sites More sharing options...
pkenewell Posted October 29, 2020 Share Posted October 29, 2020 (edited) 5 hours ago, mousho said: THX But its not working maybe u can help me to understand with what i am replacing ss in the command line Change: (setq ent (entget (ssname ss (setq in (1- in))))) to (setq ent (entget (setq en (ssname ss (setq in (1- in)))))) Then replace the "ss" variable with "en" in your command string. Let me know if that works - I haven't tested. Edited October 29, 2020 by pkenewell Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 29, 2020 Share Posted October 29, 2020 Maybe just select them like so and make your changes in the property palette ? (defun c:foo (/ s) (cond ((setq s (ssget "_X" '((0 . "*DIMENSION")))) (foreach e (mapcar 'cadr (ssnamex s)) (or (member '(100 . "AcDbRotatedDimension") (entget e)) (ssdel e s)) ) (sssetfirst nil s) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
LanloyLisp Posted October 30, 2020 Share Posted October 30, 2020 (ssget "x" (list (cons 0 "Dimension")(cons 70 0))); include code 70 with 0 value for rotated dimensions. Quote Link to comment Share on other sites More sharing options...
mousho Posted October 30, 2020 Author Share Posted October 30, 2020 Thx to all lanloylisp (cons 70 0) select "arc length dimmension" i change it to (cons 70 32) and it work where can i read about cons and what each number represent? tharwat i try the code at home and get error, i try it again at work and see if i get error there to Quote Link to comment Share on other sites More sharing options...
LanloyLisp Posted October 30, 2020 Share Posted October 30, 2020 33 minutes ago, mousho said: Thx to all lanloylisp (cons 70 0) select "arc length dimmension" i change it to (cons 70 32) and it work where can i read about cons and what each number represent? tharwat i try the code at home and get error, i try it again at work and see if i get error there to Hi Mousho, have a look on the link below.Hope it helps. https://documentation.help/AutoCAD-DXF/WS1a9193826455f5ff18cb41610ec0a2e719-7a2a.htm#WSc30cd3d5faa8f6d8e3b895ffb7556c21-7ff5 Quote Link to comment Share on other sites More sharing options...
vuxvix Posted October 13, 2021 Share Posted October 13, 2021 Hi! In a drawing with many rows of dims (horizontal, vertical, diagonal...) overlapping each other. Is it possible to select linear Dimensions along a line? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 13, 2021 Share Posted October 13, 2021 Post a dwg or image Quote Link to comment Share on other sites More sharing options...
vuxvix Posted October 14, 2021 Share Posted October 14, 2021 Attached file is an example. in which there are many dim lines overlapping each other. Hope you have any solution. Thanks Sample.dwg Quote Link to comment Share on other sites More sharing options...
zwonko Posted October 15, 2021 Share Posted October 15, 2021 (edited) I asked propably the same in other topic ( ) and nobody gives solution. There is a lisp here https://translate.google.com/translate?sl=pl&tl=en&u=https://kojacek.wordpress.com/2020/04/16/dim-mo/comment-page-1/?unapproved%3D1001%26moderation-hash%3D6118beff7105091e3f92180303c41b82%23comment-1001 But it moves every dimension on curent X or Y, so if they are even not connected dimensions they are moved. Try to edit IT but i failed. Maybe it will be good for You. Also if You need just find overlap there is a Lee mac dimoverlap Edited October 15, 2021 by zwonko 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 15, 2021 Share Posted October 15, 2021 17 minutes ago, zwonko said: and nobody gives solution. Use stretch command. drag a box around dims you want to move or "strech" drag them to new location. But mhupp you can't easily select the dims on an angle like the 3rd option. use this lisp to twist your model space. two points along the dim that you want to be horizontal. once everything is stretched use dvtw again dont pick anything or enter in 0 and it will return to normal. ;;----------------------------------------------------------------------;; ;; TWISTS VIEW (defun C:DVTW (/ twa sna) (setvar 'cmdecho 0) (princ "Pick Two Points Along a Desired Hozontal Line or enter angle:") (or (setq twa (getangle)) (setq twa 0)) (setq sna twa twa (angtos twa (getvar 'aunits)) twa (strcat "-" twa) ) (vl-cmdf "_.dview" "" "tw" twa "") (setvar 'snapang sna) (setvar 'cmdecho 1) ) 1 Quote Link to comment Share on other sites More sharing options...
zwonko Posted October 15, 2021 Share Posted October 15, 2021 (edited) I'm sorry for making You angry, didn't ment to. It is not like that i think that somebody must give me solutions. I just mean for vuxvix that IT could be hard to make what he wants. @mhupp You helped me on mamy lisps and i really greatfull for this! stretch is just normal. It is "by hand". If have aby objects on between stretch frame must use layiso to isolate dimlayer only. Also sometimes there are crossing dimensions and once again have to unselect something. Also i have multileaders on same layer. It is just anoying. Of course could be done like that. The worst is not that dims are aligned but that there is always other stuff on stretch frame that must be unselected. There are so many lisp doing just so simple things that could be done in few clicks. But people making lisp to do it faster. Lisp which I've linked do nearly what "we" need. I've tried to mod it, to let user unselect other dims but i failed. Also I think that it could be somehow restricted to current zoom windows but don't know how. Thanks also for the lisp above! It will be helpfull for sure, mainly in other stuff ! Edited October 15, 2021 by zwonko Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 15, 2021 Share Posted October 15, 2021 (edited) 13 hours ago, zwonko said: I'm sorry for making You angry, didn't ment to. All good wasn't trying to sound mean. This will get you about 80% of what your looking for selecting things. will select all dimensions but the text with leaders isn't (in red) (defun c:test (/ ent) (setq p1 (getpoint "\nSelect Point 1:") p2 (getpoint "\nSelect Point 2:") ang (angle p1 p2) pi/2 (/ pi 2) fuzz 0.001 ) (setq SS (ssget "_CP" (list (polar p1 (+ ang pi/2) fuzz) (polar p1 (- ang pi/2) fuzz) (polar p2 (- ang pi/2) fuzz) (polar p2 (+ ang pi/2) fuzz)) '((0 . "dimension")) ) ) (sssetfirst nil SS) (princ) ) Edited form:https://www.cadtutor.net/forum/topic/17875-how-to-select-objects-that-touch-a-line/?do=findComment&comment=147198 Edited October 16, 2021 by mhupp fixed code Quote Link to comment Share on other sites More sharing options...
zwonko Posted October 16, 2021 Share Posted October 16, 2021 (edited) Thank You @mhupp! Never thought it could be done just by two clicks instead of selecting dim. It was even 99%. To get it to work added just a line with stretch and correct (0 . "dimension") . Even that tooks me 1,5hour (defun c:dimstretch (/ ent p1 p2 fuzz ang) (setq p1 (getpoint "\nSelect Point 1:") p2 (getpoint "\nSelect Point 2:") ang (angle p1 p2) pi/2 (/ pi 2) fuzz 0.1 ) (setq SS (ssget "_CP" (list (polar p1 (+ ang pi/2) fuzz) (polar p1 (- ang pi/2) fuzz) (polar p2 (- ang pi/2) fuzz) (polar p2 (+ ang pi/2) fuzz)) '((0 . "dimension")) ) ) (command "stretch" ss "" p1 pause) (princ) ) But there is some problem with some dims. Look on the attached DWG (dims marked RED). Don't know why exacly... It looks like problem is with the dims below something. Tried to make it another way, using thing like (command "isolateobjects" ss1 "") ; isolating all dims (setq poin1 (polar p1 (- ang pi/2) fuzz)) (setq poin2 (polar p2 (+ ang pi/2) fuzz)) (command "stretch" poin2 poin1 "" p1 pause) ; made stretch working on crossing polygon instead off objects But still something is not working properly. No must get back to work, but later maybe i will try to changed it. dimstretch.dwg Edited October 16, 2021 by zwonko Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 16, 2021 Share Posted October 16, 2021 36 minutes ago, zwonko said: But there is some problem with dims below something. Look on the attached DWG (dims marked RED). Don't know why. Noticed if you snap to the text of the dimension it would only move the text. is this the problem you are talking about? was able to move the red dims with out problem. set osnap to only midpoint so you can quickly pick the midpoint of the dim line and avoid picking the dim text updated the stretch command to use p2 instead so you don't have to mouse over back to p1 (defun c:dimstretch (/ ent p1 p2 fuzz ang) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 2) (setq p1 (getpoint "\nSelect Point 1:") p2 (getpoint "\nSelect Point 2:") ang (angle p1 p2) pi/2 (/ pi 2) fuzz 0.1 ) (setq SS (ssget "_CP" (list (polar p1 (+ ang pi/2) fuzz) (polar p1 (- ang pi/2) fuzz) (polar p2 (- ang pi/2) fuzz) (polar p2 (+ ang pi/2) fuzz)) '((0 . "dimension")) ) ) (command "stretch" ss "" p2 pause) (setvar 'osmode oldsnap) (princ) ) Quote Link to comment Share on other sites More sharing options...
zwonko Posted October 16, 2021 Share Posted October 16, 2021 6 hours ago, mhupp said: Noticed if you snap to the text of the dimension it would only move the text. is this the problem you are talking about? No, it is not that. Looks like it is ZWCAD problem. On AUTOCAD works perfecly. Some of the red dims move with the attachment points so stretch result can be like here. \ Nut... tried to change fuzz and it works. If fuzz is example 0.1 or 0.01 or 1 is not working properly. For fuzz 2, 5, 7, 20 not working at all (nothing is stretched). For fuzz 10,50,100 works perfectly o_O Quote Link to comment Share on other sites More sharing options...
vuxvix Posted October 17, 2021 Share Posted October 17, 2021 Chào! @zwonko @mhupp I have read your topic. I also tried using the DIM-MO lisp. After the "Dimension selection" prompt, nothing happens. -The lisp in the replies I have also tried (everything seems to be around the stretch command). It is similar to the way I am using below: Use the command Stretch + macro selection Dims ( horizal or vertical ) However, my Horizal macro sometimes works incorrectly. Can you check it out!? Thanks -Based on Lisp Dimstrech: Is it possible to add an operation to deselection Dimensions horizontally or vertically (optional)!? Sel Hor_Ver Dimensions.txt Quote Link to comment Share on other sites More sharing options...
