PeterPan9720 Posted October 29, 2020 Posted October 29, 2020 6 minutes ago, lrm said: Please ignore my last post! I did not finish it. Need to compare successive coordinate pairs but need to work on something else right now. I guess @kalsefar now need a way to find "similar" cell value, because with countif and procedure I showed him, he solved the duplicated value, I guess your code should be rearrange in order to do this, but many time asked which is the value difference from a cell to another in order to define them similar but I never received answer. Look at post exchanged. Quote
Kalsefar Posted October 29, 2020 Author Posted October 29, 2020 (edited) Dude, Believe me, I have good knowledge about VBA, I tried to work with your solution but I failed maybe there is a misunderstanding, my requirements is a way that's can help me to compare and find the similar values like : 21,649004 39,398330 21,649005 39,398329 As you can see, the numbers are the same except for the sixth number after the comma, it is different If you can write a code to do that, please attach the excel file that's will be kind of you @PeterPan9720 Edited October 29, 2020 by Kalsefar 1 Quote
lrm Posted October 30, 2020 Posted October 30, 2020 Let's say you have a 2 dimensional array named LatLong where the first index is the data number and the second is 1 for latitude and 2 for longitude. i and j are indices indicating which data readings you want to compare. Comparing the two sets of coordinates as follows should tell you if the are "similar" (equal to the number of specified decimal places). n = InputBox("Specify the number of decimal places for comparison." , "Specify Precision", 6) a = Round(LatLong(i, 1), n) b = Round(LatLong(j, 1), n) c = Round(LatLong(i, 2), n) d = Round(LatLong(j, 2), n) If a = b And c = d Then ' we have a duplicate Else ' not a duplicate End If 1 Quote
lrm Posted October 30, 2020 Posted October 30, 2020 I think the following works. I tested it on your data for 4, 5, and 6 decimal places. Option Base 1 Sub test() 'Removes Lat Long coordinates pairs that are duplicated within ' a spedified precision. 'LRM 10 / 29 / 2020 ver 1 Dim LatLong(100, 2) As Variant Dim n As Integer, i As Integer, k As Integer, num As Integer Dim a As Double, b As Double, c As Double, d As Double i = 1 msg = "Please enter desired number of decimal places" & vbCrLf & _ "of desired precision." n = InputBox(msg, "Specify Precision", 6) Range("B2:B2").Select While ActiveCell.Value <> "" LatLong(i, 1) = ActiveCell.Value ActiveCell.Offset(0, 1).Select LatLong(i, 2) = ActiveCell.Value ActiveCell.Offset(1, -1).Select i = i + 1 Wend num = i - 1 LatLong(1, 1) = LatLong(1, 1) LatLong(1, 2) = LatLong(1, 2) For i = 1 To num - 1 k = 0 For j = i + 1 To num a = Round(LatLong(i, 1), n) b = Round(LatLong(j, 1), n) c = Round(LatLong(i, 2), n) d = Round(LatLong(j, 2), n) If a = b And c = d Then ' we have a duplicate k = k + 1 Else LatLong(j - k, 1) = LatLong(j, 1) LatLong(j - k, 2) = LatLong(j, 2) End If Next j Next i ' Output results Range("E2:F101").Select Selection.ClearContents Range("e2:e2").Select For i = 1 To num ActiveCell.Value = LatLong(i, 1) ActiveCell.Offset(0, 1).Select ActiveCell.Value = LatLong(i, 2) ActiveCell.Offset(1, -1).Select If Round(LatLong(i, 1), n) = Round(LatLong(i + 1, 1), n) And _ Round(LatLong(i, 2), n) = Round(LatLong(i + 1, 2), n) Then i = num End If Next i End Sub 1 Quote
Kalsefar Posted October 30, 2020 Author Posted October 30, 2020 (edited) Thank you guys, @PeterPan9720 @lrm I found a way to help my requirements, but I need VBA code to sort data automatically from largest to smallest or vice versa Edited October 30, 2020 by Kalsefar 1 Quote
PeterPan9720 Posted October 30, 2020 Posted October 30, 2020 (edited) 12 minutes ago, Kalsefar said: Thank you guys, @PeterPan9720 @lrm I found a way to help my requirements, but I need VBA code to sort data automatic from largest to smallest or vice versa @Kalsefar So due to are expert with VBA, you should know that excel allows you to record a macro while you are making action, so I suggest to start a macro recording, do the sort as you wish, ascendant or descendant, and retrive the code you require at the end of the actions. In any case your first request was to search duplicated value, and seems you solved your issue, later you are asking of find similar value that is another kind of issue. In addition, even if I'm not forum moderator, I would like to highlight that this is not an Excel Forum, but based on Autocad customization by VBA or .NET Edited October 30, 2020 by PeterPan9720 Quote
Kalsefar Posted October 30, 2020 Author Posted October 30, 2020 1 minute ago, PeterPan9720 said: @Kalsefar So due to are expert with VBA, you should know that excel allows you to record a macro while you are making action, so I suggest to start a macro recording, do the sort as you wish, ascendant or descendant, and retrive the code you require at the end of the actions. In any case you first request was to search duplicated value, and seems you solved your issue, later you are asking of find similar value that is another kind of issue. Dude since the beginning I was asking for a cod to help me to find similar values, I wonder why you didn't get my point, by the way. I appreciate your kind help. 1 Quote
PeterPan9720 Posted October 30, 2020 Posted October 30, 2020 (edited) 3 minutes ago, Kalsefar said: Dude since the beginning I was asking for a cod to help me to find similar values, I wonder why you didn't get my point, by the way. I appreciate your kind help. Dude, please look at your post, you are searching in the first time only for duplicated value, and this is a forum not a company payed for solve your issue. Bye Edited October 30, 2020 by PeterPan9720 Quote
Kalsefar Posted October 30, 2020 Author Posted October 30, 2020 2 minutes ago, PeterPan9720 said: Dude, please look at your post, you are searching in the first time only for duplicated value, and this is a forum not a company payed for solve your issue. Bye chill out, 1 Quote
eldon Posted October 30, 2020 Posted October 30, 2020 47 minutes ago, Kalsefar said: ........I found a way to help my requirements, but I need VBA code to sort data automatically from largest to smallest or vice versa Are you not allowed to use the inbuilt Sort function in Excel? 1 Quote
Kalsefar Posted October 30, 2020 Author Posted October 30, 2020 15 minutes ago, eldon said: Are you not allowed to use the inbuilt Sort function in Excel? It's allowed, but I'm creating a program so I need all functions to work automatically 1 Quote
lrm Posted October 30, 2020 Posted October 30, 2020 Here's VBA code for sorting using the bubble method. Sub Bubble(n, a, b) 'sorts an array in ascending order using the bubble sort method 'n: the number of elements to be sorted (input) 'a: the unsorted array (input) 'b: the sorted array (output) ' from Chapra, "Power Programming with VBA/Excel", p 156 ' modified by LRM 4/10/2009 to work with Option Base 1 or Base 0 ' Dim m As Integer, i As Integer Dim switch As Boolean Dim dum As Double, Base As Integer Base = 0 ' test if option base is 0 or base 1 If LBound(a) = 1 Then Base = 1 'copy a array to b array For i = Base To Base + n - 1 b(i) = a(i) Next i m = Base + n - 2 Do ' loop through passes switch = False For i = Base To m ' loop through array If b(i) > b(i + 1) Then dum = b(i) b(i) = b(i + 1) b(i + 1) = dum switch = True End If Next i If switch = False Then Exit Do m = m - 1 Loop End Sub 1 Quote
Juanma Posted November 2, 2020 Posted November 2, 2020 171/5000 I give you an excel that does what you ask.once the data is included, you just have to copy-paste as values, the two columns with the good data.Hope this can help you Test-resuelto.xlsx Quote
