Please I need urgent Excel code
I have a lot of points as Decimal Degrees, I need code for excel that can help me to
1-remove the duplicate points
2- remove the points with a specific range I can decide
Test.xlsx
Edited by Kalsefar
  • Thanks 1
Coulisse you share the excel file? And an example of the required result??
If you can share the file should be better for testing procedure. What the sentence "last number" ?
Edited by PeterPan9720
2 minutes ago, Kalsefar said:
I attached Excel file. @PeterPan9720
Ok, but you talk about duplicated not similar, what if similar ? how much similar could it be ?
8 hours ago, Kalsefar said:
I have good knowledge of IF function, but I need a VBA code in excel.
@PeterPan9720
Sub test()
For Each cell In ThisWorkbook.Sheets(1).Range("B2:B15")
    Set Arg1 = Sheets(1).Range("B2:B15")
    Arg2 = Sheets(1).Range("B" & cell.Row).Value
    Set Arg3 = Sheets(1).Range("C2:C15")
    Arg4 = Sheets(1).Range("C" & cell.Row).Value
    Sheets(1).Range("E" & cell.Row).Value = Application.WorksheetFunction.CountIfs(Arg1, Arg2, Arg3, Arg4) > 1
Next
End Sub
@Kalsefar
If the value of Cells in column "E" will be true means that cell with lat & long on specific row it's duplicated, if false not.
Of course you can use a wide range, more filtering criteria adding Arg to function, and a variable instead writing a value TRUE or FALSE in the specific cell.If you want you can delete the Row, everything checking if result from function it's true or false.
Test.xlsx
  • Thanks 1
8 minutes ago, Kalsefar said:
Thanks your code was helpful
@PeterPan9720
@Kalsefar,
It was only helpful or did you solve your issue ?
If you remove from the function the check ">1" the function return the amount of duplicated cells as 1 or 2 or more it's depending from how many times the criteria count will be true.
Of course you will find 2 times or more the duplicated value because during the scan of entire range the first cell range will be duplicated and continuing the scan up to the last range value the second cell duplicated value has been found. See attached column "F".
Test.xlsx
No didn't solve my issue,
its help me with duplicate but I need something help me with similar values like (23.855024), (23855025
So I need to highlight or write ( False ) on one of the the mentioned above value
@PeterPan9720
I would approach this by first sorting. Then the code is simplified by comparing with the value in the previous line.
  • Thanks 1
@PeterPan9720
Add a range and  criteria , or place another count if only with higher or lower criteria, the function it's always the same.
Set Arg5 = Sheets(1).Range("C2:C15")
Arg6 = Sheets(1).Range("C" & cell.Row).Value > 0,0001 'Example
Sheets(1).Range("E" & cell.Row).Value = Application.WorksheetFunction.CountIfs(Arg1, Arg2, Arg3, Arg4, Arg5, Arg6) > 1
1 hour ago, Kalsefar said:
Unfortunately still does not work.
@PeterPan9720
Ok did you define a criteria ? what I showed in my previous post it's only an example, you should define a criteria, a cells value between it's considered similar each others.
Try to separate from duplicated function value, just to understand if it's working, look on web there are a lot of literature on Excel function and VBA, see for example https://stackoverflow.com/questions/32332301/how-to-use-countifs-formula-in-vba web site.
Made experiment, I cannot make miracle, and I don't know your requirements.
Again you should create a your criteria of selected value for example cell A2 value between cell A3 +/- 0,00001.
One range -> One criteria -> One Arg..n in the function. Try with a couple of cells.
Does the following do what you want for removing duplicate coordinate pairs?
I had the program output the results into columns E and F.  The code does not do any error processing and has only been lightly tested.
Option Base 1
Sub test()
'Removes Lat Long coordinates pairs that are duplicated within
' a spedified precision.
'LRM 10 / 29 / 2020
Dim LatLong(100, 2) As Variant
Dim LatLongNew(100, 2) As Double
Dim n As Integer, i As Integer, k As Integer, num As Integer
i = 1
msg = "Please enter desired number of decimal places" & vbCrLf & _
"of desired precision."
n = InputBox(msg, "Specify Precision", 6)
Range("B2:B2").Select
While ActiveCell.Value <> ""
LatLong(i, 1) = ActiveCell.Value
ActiveCell.Offset(0, 1).Select
LatLong(i, 2) = ActiveCell.Value
ActiveCell.Offset(1, -1).Select
i = i + 1
Wend
num = i - 1
k = 1
For i = 1 To num - 1
    If Round(LatLong(i, 1), n) <> Round(LatLong(i + 1, 1), n) Then
        If Round(LatLong(i, 2), n) <> Round(LatLong(i + 1, 2), n) Then
            ' we don't have a duplicate
            LatLongNew(k, 1) = LatLong(i, 1)
            LatLongNew(k, 2) = LatLong(i, 2)
            k = k + 1
        End If
    End If
Next i
' Output results
Range("E2:F101").Select
Selection.ClearContents
Range("e2:e2").Select
For i = 1 To k - 1
    ActiveCell.Value = LatLongNew(i, 1)
    ActiveCell.Value = LatLong(i, 2)
Next i
End Sub
  • Thanks 1
PLease ignore my last post!  I did not finish it.  Need to  compare successive coordinate pairs but need to work on something else right now.
