Kalsefar Posted October 27, 2020 Posted October 27, 2020 (edited) I have a lot of points as Decimal Degrees, I need code for excel that can help me to 1-remove the duplicate points 2- remove the points with a specific range I can decide Test.xlsx Edited October 27, 2020 by Kalsefar 1 Quote
PeterPan9720 Posted October 27, 2020 Posted October 27, 2020 1 minute ago, Kalsefar said: I have a lot of points as Decimal Degrees, I need code for excel that can help me to 1-remove the duplicate points 2- remove the points with a specific range I can decide Coulisse you share the excel file? And an example of the required result?? Quote
Kalsefar Posted October 27, 2020 Author Posted October 27, 2020 I attached a picture I hope the required is clear now. @PeterPan9720 1 Quote
PeterPan9720 Posted October 27, 2020 Posted October 27, 2020 (edited) 24 minutes ago, Kalsefar said: I have a lot of points as Decimal Degrees, I need code for excel that can help me to 1-remove the duplicate points 2- remove the points with a specific range I can decide If you can share the file should be better for testing procedure. What the sentence "last number" ? Edited October 27, 2020 by PeterPan9720 Quote
Kalsefar Posted October 27, 2020 Author Posted October 27, 2020 I attached Excel file. @PeterPan9720 Quote
PeterPan9720 Posted October 27, 2020 Posted October 27, 2020 2 minutes ago, Kalsefar said: I attached Excel file. @PeterPan9720 Ok, but you talk about duplicated not similar, what if similar ? how much similar could it be ? Quote
Kalsefar Posted October 27, 2020 Author Posted October 27, 2020 That's the problem of how I can find similar data by specific value @PeterPan9720 Quote
PeterPan9720 Posted October 27, 2020 Posted October 27, 2020 1 minute ago, Kalsefar said: That's the problem of how I can find similar data by specific value @PeterPan9720 https://www.ablebits.com/office-addins-blog/2016/03/02/identify-duplicates-excel/#identify-duplicates-excel You can find equal not similar, for similar you have to define a criteria ! 1 decimal point ? n decimal point ?... look at link Quote
PeterPan9720 Posted October 27, 2020 Posted October 27, 2020 8 minutes ago, PeterPan9720 said: https://www.ablebits.com/office-addins-blog/2016/03/02/identify-duplicates-excel/#identify-duplicates-excel You can find equal not similar, for similar you have to define a criteria ! 1 decimal point ? n decimal point ?... look at link See example file attached. Test.xlsx Quote
Kalsefar Posted October 27, 2020 Author Posted October 27, 2020 I have good knowledge of IF function, but I need a VBA code in excel. @PeterPan9720 1 Quote
PeterPan9720 Posted October 27, 2020 Posted October 27, 2020 (edited) 8 hours ago, Kalsefar said: I have good knowledge of IF function, but I need a VBA code in excel. @PeterPan9720 Sub test() For Each cell In ThisWorkbook.Sheets(1).Range("B2:B15") Set Arg1 = Sheets(1).Range("B2:B15") Arg2 = Sheets(1).Range("B" & cell.Row).Value Set Arg3 = Sheets(1).Range("C2:C15") Arg4 = Sheets(1).Range("C" & cell.Row).Value Sheets(1).Range("E" & cell.Row).Value = Application.WorksheetFunction.CountIfs(Arg1, Arg2, Arg3, Arg4) > 1 Next End Sub @Kalsefar If the value of Cells in column "E" will be true means that cell with lat & long on specific row it's duplicated, if false not. Of course you can use a wide range, more filtering criteria adding Arg to function, and a variable instead writing a value TRUE or FALSE in the specific cell.If you want you can delete the Row, everything checking if result from function it's true or false. Test.xlsx Edited October 28, 2020 by PeterPan9720 1 Quote
Kalsefar Posted October 28, 2020 Author Posted October 28, 2020 Thanks your code was helpful @PeterPan9720 1 Quote
PeterPan9720 Posted October 28, 2020 Posted October 28, 2020 8 minutes ago, Kalsefar said: Thanks your code was helpful @PeterPan9720 @Kalsefar, It was only helpful or did you solve your issue ? If you remove from the function the check ">1" the function return the amount of duplicated cells as 1 or 2 or more it's depending from how many times the criteria count will be true. Of course you will find 2 times or more the duplicated value because during the scan of entire range the first cell range will be duplicated and continuing the scan up to the last range value the second cell duplicated value has been found. See attached column "F". Test.xlsx Quote
Kalsefar Posted October 28, 2020 Author Posted October 28, 2020 No didn't solve my issue, its help me with duplicate but I need something help me with similar values like (23.855024), (23855025 So I need to highlight or write ( False ) on one of the the mentioned above value @PeterPan9720 Quote
eldon Posted October 28, 2020 Posted October 28, 2020 I would approach this by first sorting. Then the code is simplified by comparing with the value in the previous line. 1 Quote
PeterPan9720 Posted October 28, 2020 Posted October 28, 2020 (edited) 2 hours ago, Kalsefar said: No didn't solve my issue, its help me with duplicate but I need something help me with similar values like (23.855024), (23855025 So I need to highlight or write ( False ) on one of the the mentioned above value @PeterPan9720 Add a range and criteria , or place another count if only with higher or lower criteria, the function it's always the same. Set Arg5 = Sheets(1).Range("C2:C15") Arg6 = Sheets(1).Range("C" & cell.Row).Value > 0,0001 'Example Sheets(1).Range("E" & cell.Row).Value = Application.WorksheetFunction.CountIfs(Arg1, Arg2, Arg3, Arg4, Arg5, Arg6) > 1 Edited October 28, 2020 by PeterPan9720 Quote
Kalsefar Posted October 29, 2020 Author Posted October 29, 2020 Unfortunately still does not work. @PeterPan9720 1 Quote
PeterPan9720 Posted October 29, 2020 Posted October 29, 2020 1 hour ago, Kalsefar said: Unfortunately still does not work. @PeterPan9720 Ok did you define a criteria ? what I showed in my previous post it's only an example, you should define a criteria, a cells value between it's considered similar each others. Try to separate from duplicated function value, just to understand if it's working, look on web there are a lot of literature on Excel function and VBA, see for example https://stackoverflow.com/questions/32332301/how-to-use-countifs-formula-in-vba web site. Made experiment, I cannot make miracle, and I don't know your requirements. Again you should create a your criteria of selected value for example cell A2 value between cell A3 +/- 0,00001. One range -> One criteria -> One Arg..n in the function. Try with a couple of cells. Quote
lrm Posted October 29, 2020 Posted October 29, 2020 Does the following do what you want for removing duplicate coordinate pairs? I had the program output the results into columns E and F. The code does not do any error processing and has only been lightly tested. Option Base 1 Sub test() 'Removes Lat Long coordinates pairs that are duplicated within ' a spedified precision. 'LRM 10 / 29 / 2020 Dim LatLong(100, 2) As Variant Dim LatLongNew(100, 2) As Double Dim n As Integer, i As Integer, k As Integer, num As Integer i = 1 msg = "Please enter desired number of decimal places" & vbCrLf & _ "of desired precision." n = InputBox(msg, "Specify Precision", 6) Range("B2:B2").Select While ActiveCell.Value <> "" LatLong(i, 1) = ActiveCell.Value ActiveCell.Offset(0, 1).Select LatLong(i, 2) = ActiveCell.Value ActiveCell.Offset(1, -1).Select i = i + 1 Wend num = i - 1 k = 1 For i = 1 To num - 1 If Round(LatLong(i, 1), n) <> Round(LatLong(i + 1, 1), n) Then If Round(LatLong(i, 2), n) <> Round(LatLong(i + 1, 2), n) Then ' we don't have a duplicate LatLongNew(k, 1) = LatLong(i, 1) LatLongNew(k, 2) = LatLong(i, 2) k = k + 1 End If End If Next i ' Output results Range("E2:F101").Select Selection.ClearContents Range("e2:e2").Select For i = 1 To k - 1 ActiveCell.Value = LatLongNew(i, 1) ActiveCell.Offset(0, 1).Select ActiveCell.Value = LatLong(i, 2) ActiveCell.Offset(1, -1).Select Next i End Sub 1 Quote
lrm Posted October 29, 2020 Posted October 29, 2020 PLease ignore my last post! I did not finish it. Need to compare successive coordinate pairs but need to work on something else right now. Quote
