Hallo,
I have a CSV in the format Layer, x, y, z, text.
So would like to use the Layer colum to put the text in different layers.
Gerard
Here's a simple example using my Read CSV function:
(defun c:txtfromcsv ( / csv des hgt ins itm str sty )
    (setq hgt (getvar 'textsize)
          sty (getvar 'textstyle)
    (cond
        (   (not (setq csv (getfiled "Select CSV File" "" "csv" 16)))
            (princ "\n*Cancel*")
        (   (not (setq des (open csv "r")))
            (princ "\nUnable to open CSV file for reading.")
        (   t
            (while (setq str (read-line des))
                (setq itm (LM:csv->lst str "," 0))
                (if (and (< 3 (length itm))
                         (snvalid (car itm))
                         (apply 'and (setq ins (mapcar 'distof (mapcar '(lambda ( a b ) a) (cdr itm) '(0 1 2)))))
                    (entmake
                        (list
                           '(000 . "TEXT")
                            (cons 010 ins)
                            (cons 007 sty)
                            (cons 040 hgt)
                            (cons 001 (last itm))
                            (cons 008 (car  itm))
            (close des)
;; CSV -> List  -  Lee Mac
;; Parses a line from a CSV file into a list of cell values.
;; str - [str] string read from CSV file
;; sep - [str] CSV separator token
;; pos - [int] initial position index (always zero)
(defun LM:csv->lst ( str sep pos / s )
    (cond
        (   (not (setq pos (vl-string-search sep str pos)))
            (if (wcmatch str "\"*\"")
                (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2))))
                (list str)
        (   (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
                (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
            (LM:csv->lst str sep (+ pos 2))
        (   (wcmatch s "\"*\"")
            (cons
                (LM:csv-replacequotes (substr str 2 (- pos 2)))
                (LM:csv->lst (substr str (+ pos 2)) sep 0)
        (   (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0)))
(defun LM:csv-replacequotes ( str / pos )
    (setq pos 0)
    (while (setq pos (vl-string-search  "\"\"" str pos))
        (setq str (vl-string-subst "\"" "\"\"" str pos)
              pos (1+ pos)
    str
Tried to add rotate column before text column and I modified the code at entmake
output ; error: bad DXF group: (50 . "0.000000000000000")
Please help
(entmake
                        (list
                           '(000 . "TEXT")
                            (cons 010 ins)
                            (cons 007 sty)
                            (cons 040 hgt)
                            (cons 050 (car (cdr (reverse itm))))
The rotation angle will need to be a numerical value expressed in radians, and so assuming that your text file contains a value in degrees, try:
(cons 050 (* pi (/ (atof (cadr (reverse itm))) 180.0)))
