I am trying to make a robotic arm. The base is connected to rotate. Which is connected to link 2 which in turn joins with link3. Hook is attached to link 3. I want to move the links 2 and link3 up and down, but none of my constrainst seem to work and it won't let me animate it. Can you please help me out.
I have also uplaoded the assembly and I used joints for the links as well. Where am I going wrong?
rotate.iptFetching info... link3.iptFetching info... link2.iptFetching info... hook.iptFetching info... base.iptFetching info... Assembly.iamFetching info...
Are you using Autocad or Inventor? You posted in the Autocad Beginners section but all the files you provided are Inventor files.
Yes I am using inventor. Sorry it was a mistake on my part.
Expand
Ok, I have moved your question to the Autodesk Inventor section. I don't use Inventor but hopefully someone else will be able to help you.
