Kalsefar Posted October 23, 2020 Share Posted October 23, 2020 Hello Everyone, please, I need a code ( lisp ) that can help me to make offset for multiple objects at the same time. 1 Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 23, 2020 Share Posted October 23, 2020 Your answer is most likely somewhere in this thread. 1 Quote Link to comment Share on other sites More sharing options...
Kalsefar Posted October 23, 2020 Author Share Posted October 23, 2020 None of it help me @ronjonp Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 23, 2020 Share Posted October 23, 2020 (edited) 30 minutes ago, Kalsefar said: None of it help me @ronjonp Here's a quickie: (defun c:foo (/ d s) ;; RJP » 2020-10-23 (if (and (setq d (getdist "\nOffset distance: ")) (setq s (ssget ":L" '((0 . "~INSERT"))))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (vl-catch-all-apply 'vlax-invoke (list (vlax-ename->vla-object e) 'offset d)) ) ) (princ) ) (vl-load-com) Edited October 23, 2020 by ronjonp 1 1 Quote Link to comment Share on other sites More sharing options...
Kalsefar Posted October 23, 2020 Author Share Posted October 23, 2020 Your code very helpful, and sorry for disturbing you but can you show me a way how I can make a Dialog box for your code so I can insert the distance in the dialog?! if it possible and you have time thanks a lot @ronjonp Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 23, 2020 Share Posted October 23, 2020 1 hour ago, Kalsefar said: Your code very helpful, and sorry for disturbing you but can you show me a way how I can make a Dialog box for your code so I can insert the distance in the dialog?! if it possible and you have time thanks a lot @ronjonp Sorry no time to make it pretty. Why can't you just enter the value in the command line ( or pick two points )? 1 Quote Link to comment Share on other sites More sharing options...
Kalsefar Posted October 23, 2020 Author Share Posted October 23, 2020 Sorry due to I asking much , But can you please edit the code to I able to add number of offsets, I tried to edit but I failed Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 23, 2020 Share Posted October 23, 2020 (edited) On 10/23/2020 at 4:05 PM, Kalsefar said: Sorry due to I asking much , But can you please edit the code to I able to add number of offsets, I tried to edit but I failed No worries ... try this. Heading out for the weekend! (defun c:foo (/ b d f n s) ;; RJP » 2020-10-23 (if (and (setq d (getdist "\nOffset distance: ")) ;; Edit (setq n 1) per Roy .. Thanks! (or (setq n (getint "\nNumber of offsets:<1>")) (setq n 1)) (setq s (ssget ":L" '((0 . "~INSERT")))) (setq s (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))) ) (progn (foreach e (mapcar 'vlax-ename->vla-object s) (setq f t) (setq b n) (while (and (> (setq b (1- b)) -1) f) (if (setq f (= 'list (type (setq e (vl-catch-all-apply 'vlax-invoke (list e 'offset d)))))) (setq e (car e)) (setq f nil) ) ) ) ;; Delete orginal offset objects (mapcar 'entdel s) ) ) (princ) ) (vl-load-com) Edited October 26, 2020 by ronjonp *Fixed a couple of errors Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 24, 2020 Share Posted October 24, 2020 (edited) A couple of suggestions the first multiple offset input, just type each offset seperated by a comma. ; thanks to Lee-mac for this defun ; www.lee-mac.com ; 44 is comma (defun _csv->lst ( str / pos ) (if (setq pos (vl-string-position 44 str)) (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2)))) (list str) ) ) (defun C:MULOFF ( / obj s off) (vl-load-com) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (setq offs (getstring "\Enter offsets seperated by a comma eg 1,2,3 ")) (setq lst (csv->lst offs)) (foreach off lst (command "_.offset" off obj s "") ) (princ) ) (c:muloff) Re a dcl for input go to downloads here and have a look at multi getvals.lsp, multi radio buttons.lspMulti GETVALS.lsp ; thanks to Lee-mac for this defun ; www.lee-mac.com ; 44 is comma (defun _csv->lst ( str / pos ) (if (setq pos (vl-string-position 44 str)) (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2)))) (list str) ) ) (defun C:MULOFF ( / obj s off) (vl-load-com) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setq offs (nth 0 (AH:getvalsm (list "Enter values" "Offsets seperate by , " 30 29 "1,2,3" )))) (setq lst (csv->lst offs)) (foreach off lst (command "_.offset" off obj s "") ) (princ) ) (c:muloff) Edited October 24, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 24, 2020 Share Posted October 24, 2020 (edited) 3 hours ago, BIGAL said: A couple of suggestions the first multiple offset input, just type each offset seperated by a comma. (defun C:MULOFF ( / obj s off) (vl-load-com) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (setq offs (getstring "\Enter offsets seperated by a comma eg 1,2,3 ")) (setq lst (csv->lst offs)) (foreach off lst (command "_.offset" off obj s "") ) (princ) ) (c:muloff) Re a dcl for input go to downloads here and have a look at multi getvals.lsp, multi radio buttons.lspMulti GETVALS.lsp (defun C:MULOFF ( / obj s off) (vl-load-com) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setq offs (nth 0 (AH:getvalsm (list "Enter values" "Offsets seperate by , " 30 29 "1,2,3" )))) (setq lst (csv->lst offs)) (foreach off lst (command "_.offset" off obj s "") ) (princ) ) (c:muloff) @BIGAL With all the pictures intact you're introducing a missing (csv->lst) function and less functionality of a simple command line input which both accepts a picked distance or number? You really should validate user input before passing them along .. have you thought about that? .. Sorry you have many posts that seem to SPAM many good replies ( this one included ) ;/ FWIW less links to your AH:* functions and pictures and provide a complete solution. Most people cannot or will not assemble your puzzles. Edited October 24, 2020 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted October 24, 2020 Share Posted October 24, 2020 @ronjonp Small issue: (or (setq n (getint "\nNumber of offsets:<1>")) 1) I think this should be: (or (setq n (getint "\nNumber of offsets:<1>")) (setq n 1)) 1 Quote Link to comment Share on other sites More sharing options...
Kalsefar Posted October 24, 2020 Author Share Posted October 24, 2020 Re a dcl for input go to downloads here and have a look at multi getvals.lsp, multi radio buttons.lspMulti GETVALS.lsp Please What is the shortcut for run the multi getvals.lsp ?! Quote Link to comment Share on other sites More sharing options...
Kalsefar Posted October 24, 2020 Author Share Posted October 24, 2020 Sir @ronjonp can you please change the code to delete the original item after creating the offset directly Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 24, 2020 Share Posted October 24, 2020 (edited) I have updated the code posted, and added the csv->lst yes that was a mistake by me. Inside the multi getval and radio buttons lisps are various examples on how to use if you look. In the code posted there is 2 lines (if (not AH:getvalsm)(load "Multi Getvals.lsp")) this loads the Multi getvals.lsp code if not already loaded, it just needs to be in a support path or you can add the correct location "c:\\mydirectory\\oflisps\\Muti getvals.lsp" on your computer, note the \\ for directory names. 2nd line (setq offs (nth 0 (AH:getvalsm (list "Enter values" "Offsets seperated by , " 30 29 "1,2,3" )))) this is the code for the entry it is only 1 line in size, the box is set to a limit of 30 characters can be made more if required a list is returned of the string entered. Here is another example a list is returned of the values entered. (setq ans (AH:getvalsm (list "Enter Values" "Length " 5 4 "100" "Width" 5 4 "50" "Depth" 5 4 "25" "Gap" 5 4 "25"))) (setq len (atof (nth 0 ans)) wid (atof (nth 1 ans)) depth (atof (nth 2 ans)) gap (atof (nth 3 ans))) ; the atof converts the string to a number You can save the values entered for reuse if running the request for sizes multiple times by saving to variables. (if (= len nil)(setq len 100)) (if (= wid nil)(setq wid 50)) (if (= depth nil)(setq depth 25)) (if (= gap nil)(setq gap 25)) (setq ans (AH:getvalsm (list "Enter Values" "Length " 5 4 (rtos len 2 0) "Width" 5 4 (rtos wid 2 0) "Depth" 5 4 (rtos depth 2 0) "Gap" 5 4 (rtos gap 2 0)))) (setq len (atof (nth 0 ans)) wid (atof (nth 1 ans)) depth (atof (nth 2 ans)) gap (atof (nth 3 ans))) If you want you can copy the defun AH:getvalsm code into your code so its already available. Click on this to download Multi getvals.lsp Multi GETVALS.lsp Edited October 24, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 26, 2020 Share Posted October 26, 2020 On 10/24/2020 at 4:23 AM, Kalsefar said: Sir @ronjonp can you please change the code to delete the original item after creating the offset directly Updated the code HERE. Quote Link to comment Share on other sites More sharing options...
