  On 10/21/2020 at 1:57 PM, Tharwat said:
No but I meant something like this:
Expand
ooh! I see, I wouldn't know how to create the box, but to be honest, that way you did it is perfect, :)  it works like a dream, so nice and quick
Edited by ant7
If you like this way then just let me know to write such a working routine for you for free. :D
  • Like 3
Here is another version it allows you to type the numbers required directly on the command line. It uses a reactor to look at the error that occurs as it is not a valid command and pulls the numbers apart.
I have set up 2 and 3 as the 1st string you can add more 4 5 6 etc  so 230 will return 2 & 30 2300 2 & 300 for the 2 edits required.
A couple of buts if you have set a defun and used numbers it may cause a problem I have a few defuns that use a number like c:47 so would have to exclude in error check or just simply rename the defun.
; enter numbers on command line and split into multi text
; Enter the text as 2300 it will be split into the 1st character and then what is left
; eg 230 = 2 30 2300 = 2 300
; original code and methology by Alan H
; OCT 2015 1st version
; Oct 2020 2txt
((lambda nil
   (vl-load-com)
   (foreach obj (cdar (vlr-reactors :vlr-command-reactor))
     (if (= "text-reactor" (vlr-data obj))
       (vlr-remove obj)
    (vlr-command-reactor "text-reactor" '((:vlr-unknowncommand . text-reactor-callback)))
(defun ah:txtsplitnum (/)
  (setq txt1 (substr com 1 1))
  (setq txt2 (substr com 2))
  (vla-sendcommand text-reactor-acdoc "txt2txt ")
(defun ah:txtsplit (/)
  (setq txt1 (substr com 2 1))
  (setq txt2 (substr com 3))
(defun text-reactor-callback (obj com)
  (setq com (strcase (car com)))
  (cond
       ((and
       (wcmatch com "~*[~2.0-9]*")
       (ah:txtsplitnum)
      ( (wcmatch com "~*[~3.0-9]*")
       (ah:txtsplitnum)
(or text-reactor-acdoc
    (setq text-reactor-acdoc (vla-get-activedocument (vlax-get-acad-object)))
; two text entries by AlanH
(defun c:txt2txt (/ ss ss2)
  (princ "\n Pick 1st text")
  (setq ss (ssget "_+.:E:S" (list (cons 0 "Text"))))
  (princ "\nPick 2nd text")
  (setq ss2 (ssget "_+.:E:S" (list (cons 0 "Text"))))
  (if (and (/= ss nil) (/= ss2 nil))
      (setq ent (entget (ssname ss 0)))
      (entmod (subst (cons 1 txt1) (assoc 1 ent) ent))
      (setq ent (entget (ssname ss2 0)))
      (entmod (subst (cons 1 txt2) (assoc 1 ent) ent))
    (alert "Object picked was not text")
; Oct 2020 2txt
((lambda nil
   (vl-load-com)
       (vlr-remove obj)
  (cond
       ((and
       (ah:txtsplitnum)
       (ah:txtsplitnum)
Thank you Sir, I kindly appreciate your auto lisp, the one from MR. Tharwat  is simple and perfect  :)
Expand
