Autocad 2007 Copy paste problem
I seem to remember that the copy/paste function was a well documented bug with 2007.
Have you got all the proper updates?
as u know this the very old product and the update is not available now
I believe using a more recent version of AutoCAD and/or DWG TrueView may fix that problem for the drawing. It may keep doing that if you continue to use AutoCAD 2007 without updates though. If you must use that version, maybe try creating and inserting the items as blocks.
Was the drawing you are working on previously saved to the AutoCAD 2000 or AutoCAD 14 file format by any chance?  A Hotfix - Cut and Paste was issued by AutoDesk in July, 2006.  Refer to the link below.  Read the entire article before deciding which solution to follow.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/downloads/content/hotfix-cut-and-paste.html?st=autocad 2007 copy paste problem
