Well, the title says it all.
Is it possible to define wich version of the ACAD will open an .dwg file when doubleclicking on it?
I have two versions 2014 and 2016 and it seems that 2014 is set as default.
Can I change this to 2016?
Or just right click a drawing and go to "Open With" then select "Choose default Program" select the desired default program.
I just drag the file onto the desktop icon of my choice if not opening through the program.
