COORDINATES REQUIRED AT START END AND MID OF LINES
CADWORKER
Dear Friends,
I have a task where I have to assign coordinates to start, end and mid of lines. Each drawing has 11 lines for each for which I  need the coordinates at these locations and there are around 500 drawing.
Is there any way I can select all the lines and coordinates are plotted at the start, mid and end of the lines in one shot. Refer the drawing attached.
or is there any code which has some type of a block which can be inserted at these locations and the coordinate values are displayed as attributes and the blocks are exploded to get the results.
Kindly do the needful in getting the right and proper solution to solve this challenge.
MULTIPLE-COORDINATES.dwg
TEST THIS
(defun c:test ( /  I LIX SS)
  (prompt "\nSelect  lines...")
  (setq ss (ssget '((0 . "LINE"))))
  (if ss
        (setq lix (entget (ssname ss (setq i (1- i)))))
        (entmakex
     (list (cons 0   "MTEXT")
           (cons 100 "AcDbEntity")
           (cons 100 "AcDbMText")
           (cons 10 (cdr (assoc 10 lix)))
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr (assoc 10 lix)) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car (assoc 10 lix)) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr (assoc 10 lix)) 2 4))
        (entmakex
           (cons 10 (mapcar (function (lambda (a b) (/ (+ a b) 2.0))) (cdr (assoc 10 lix)) (cdr (assoc 11 lix))))
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr (mapcar (function (lambda (a b) (/ (+ a b) 2.0))) (cdr (assoc 10 lix)) (cdr (assoc 11 lix)))) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car (mapcar (function (lambda (a b) (/ (+ a b) 2.0))) (cdr (assoc 10 lix)) (cdr (assoc 11 lix)))) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr (mapcar (function (lambda (a b) (/ (+ a b) 2.0))) (cdr (assoc 10 lix)) (cdr (assoc 11 lix)))) 2 4))
        (entmakex
           (cons 10 (cdr (assoc 11 lix)))
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr (assoc 11 lix)) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car (assoc 11 lix)) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr (assoc 11 lix)) 2 4))
Nice, I always do the lambda divide pts / 2 as 2 steps so thanks now 1 line.
I Work in metric rtos 2 4 that is to 1/10 of a mm 2 3 is the norm for a dwg in metres.
The next step would be to use Aeccoreconsole to process 500 dwg's
I would have used VL just a personal preference
(setq lix (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
(setq start (vlax-get lix 'StartPoint))
(setq end (vlax-get lix 'EndPoint))
(setq mid (mapcar (function (lambda (a b) (/ (+ a b) 2.0))) start end))
Just a comment here in AUS E,N,Z depends where you are in the world.
  • Thanks 1
16 hours ago, hosneyalaa said:
TEST THIS
  (if ss
        (entmakex
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
        (entmakex
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
        (entmakex
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
Hosneyalaa ; Thanks for your efforts in helping me appreciate your time and efforts. I get some errors in the answers look for the attached image for result and properties.
i am sory
updata lisp
  (if ss
        (entmakex
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr (cdr(assoc 10 lix))) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car (cdr(assoc 10 lix))) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr (cdr(assoc 10 lix))) 2 4))
        (entmakex
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
        (entmakex
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr (cdr(assoc 11 lix))) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car (cdr(assoc 11 lix))) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr (cdr(assoc 11 lix))) 2 4))
thank you sir  BIGAL
The code has been modified idea  sir  BIGAL
To reduce the time
thank you
  (if ss
;;;        (setq lix (entget (ssname ss (setq i (1- i)))))
        (entmakex
           (cons 10 start)
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr start) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car start) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr start) 2 4))
        (entmakex
           (cons 10 mid)
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr mid) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car mid) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr mid) 2 4))
        (entmakex
           (cons 10 end)
           (cons 71 5)
           (cons 40 5)
           (cons 50 0)
           (cons  1
                  (strcat (strcat "N=" (rtos (cadr end) 2 4));; reversed north/east value
                          (strcat "\\PE=" (rtos (car end) 2 4));; reversed north/east value
                          (strcat "\\PZ=" (rtos (caddr end) 2 4))
There is no need to convert the entity to vla-object to retrieve data in this case at all and as you already did in the first post but you did not assign the start & end coordinates to variables as in the last reply you posted.
The following is enough.
 (setq start (cdr (assoc 10 lix)))
 (setq end   (cdr (assoc 11 lix)))
  • Thanks 1
