AutoCAD VBA - change active layer
Hello,
I am trying to change the change the active layer.
I tried this routine but no luck.
Public Sub ChangeEntityLayer()
Dim objEntity As AcadEntity
Dim varPick As Variant
Dim strLayerName As String
Dim objLayer As AcadLayer
strLayerName="Mypoints"
Set objLayer = ThisDrawing.Layers(strLayerName)
End Sub
Any ideas?
Thank you
26 minutes ago, katto01 said:
Hello,
End Sub
Any ideas?
Thank you
See On line Hep for Active Layer
Sub Example_ActiveLayer()
    ' This example returns the current layer
    ' and then adds a new layer.
    ' Finally, it returns the layer to the previous setting.
    Dim currLayer As AcadLayer
    Dim newLayer As AcadLayer
    ' Return the current layer of the active document
    Set currLayer = ThisDrawing.ActiveLayer
    MsgBox "The current layer is " & currLayer.name, vbInformation, "ActiveLayer Example"
    ' Create a Layer and make it the active layer
    Set newLayer = ThisDrawing.Layers.Add("TestLayer")
    ThisDrawing.ActiveLayer = newLayer
    MsgBox "The new layer is " & newLayer.name, vbInformation, "ActiveLayer Example"
    ' Reset the layer to its previous setting
    ThisDrawing.ActiveLayer = currLayer
    MsgBox "The active layer is reset to " & currLayer.name, vbInformation, "ActiveLayer Example"
End Sub
What you are trying to do with below code it's for retrieving all layers collection in the drawing not for set layer.
Dim objLayer As AcadLayers
strLayerName="Mypoints" 'could be used to create new layer and make it as active layer.
