mohammad-hassan Posted September 26, 2020 Share Posted September 26, 2020 hallow all This my first topic , i hope it usfull for any one sometimes we loose the line surround the hatch and hard to redraw but there is order in hatch pannel called recreate that draw poly line around the hatch Explained how to use it in this video https://www.youtube.com/watch?v=QaG3P1oE1fc best regards Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted September 28, 2020 Share Posted September 28, 2020 You can avoid that problem by using associative hatches. When you create a hatch, make sure the "Associative" box is checked, and use an object instead of a pick point. From then on, the hatch will move whenever the border object moves. 1 Quote Link to comment Share on other sites More sharing options...
mohammad-hassan Posted September 28, 2020 Author Share Posted September 28, 2020 4 hours ago, CyberAngel said: You can avoid that problem by using associative hatches. When you create a hatch, make sure the "Associative" box is checked, and use an object instead of a pick point. From then on, the hatch will move whenever the border object moves. thanks for this replay i will make sure to aply itthanks for this reply, i will make sure to apply it always Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 29, 2020 Share Posted September 29, 2020 There is a lisp that re-creates the boundary it may be in Express. 1 Quote Link to comment Share on other sites More sharing options...
guran Posted September 29, 2020 Share Posted September 29, 2020 Hatch Edit / Recreate boundary 1 Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 29, 2020 Share Posted September 29, 2020 Or just type 'HATCHGENERATEBOUNDARY' it is a core command. 1 Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 30, 2020 Share Posted September 30, 2020 Generate Boundary is also in the right click contextual menu. 1 Quote Link to comment Share on other sites More sharing options...
