mohammad-hassan Posted September 26, 2020 Posted September 26, 2020 hallow all This my first topic , i hope it usfull for any one sometimes we loose the line surround the hatch and hard to redraw but there is order in hatch pannel called recreate that draw poly line around the hatch Explained how to use it in this video https://www.youtube.com/watch?v=QaG3P1oE1fc best regards Quote
CyberAngel Posted September 28, 2020 Posted September 28, 2020 You can avoid that problem by using associative hatches. When you create a hatch, make sure the "Associative" box is checked, and use an object instead of a pick point. From then on, the hatch will move whenever the border object moves. 1 Quote
mohammad-hassan Posted September 28, 2020 Author Posted September 28, 2020 4 hours ago, CyberAngel said: You can avoid that problem by using associative hatches. When you create a hatch, make sure the "Associative" box is checked, and use an object instead of a pick point. From then on, the hatch will move whenever the border object moves. thanks for this replay i will make sure to aply itthanks for this reply, i will make sure to apply it always Quote
BIGAL Posted September 29, 2020 Posted September 29, 2020 There is a lisp that re-creates the boundary it may be in Express. 1 Quote
steven-g Posted September 29, 2020 Posted September 29, 2020 Or just type 'HATCHGENERATEBOUNDARY' it is a core command. 1 Quote
RobDraw Posted September 30, 2020 Posted September 30, 2020 Generate Boundary is also in the right click contextual menu. 1 Quote
