designer_jackie Posted September 18, 2020 Posted September 18, 2020 Hi all - I've spent so many accumulated hours searching for a basic Wood Flooring hatch. Plank, random or at least 1/3 offset (no sunning bond/1/2 offset) - you know, how pretty much all wood flooring ever done looks installed. I'm so surprised there's not an abundance of this pattern? Or at least 1 that comes with my AutoCAD LT version. Does anyone have one they could share or a reputable source to purchase from? Please see image below, something along the lines of this. Of course there are images and other forums all over google, but as soon as you click them the sites don't exist any more, or the post from 2005 no longer has the attachment (which is how I found this website). Any help would be appreciated. Quote
eldon Posted September 18, 2020 Posted September 18, 2020 Do you have any basic dimensions to use. If the hatch pattern is created for particular dimensions, then it can be used at a hatch scale of 1, much easier. Quote
BIGAL Posted September 18, 2020 Posted September 18, 2020 (edited) There is various ways here is one but its a lisp that makes hatch patterns also check out this pat file and link it uses excel to make pat files. You can edit the sizes to suit. *HT600x3003ET,600x300mm 3mm Free patterns from www.AUTOCADhatch.com 0,3,0, 0,603, 300,-3.0 0,3,3, 0,603, 300,-3.0 90,3,3, 0,303, 600,-3.0 90,0,3, 0,303, 600,-3.0 bricks.lspFetching info... Edited September 18, 2020 by BIGAL Quote
eldon Posted September 19, 2020 Posted September 19, 2020 I had a quiet afternoon so I wrote a pattern file for a Wood Flooring Hatch. It is based on a plank width of 150 drawing units, and lengths to suit your picture. One cannot have a completely random hatch pattern, but if the repeat spacing is large enough, the eye can get fooled. Here is the pattern file, and you will notice that at the end, instead of a blank line, one can put a line starting with a * and then one can put a credit for the creator. Save the file as WoodFloor.pat and put it where AutoCAD can find it. *WoodFloor, Wooden Flooring 0,0,0,0,150 90,125,0,0,3015,150,-300,150,-450 90,0,150,0,3015,150,-600,150,-150 90,280,750,0,3015,150,-900 90,470,300,0,3015,150,-900 90,565,600,0,3015,150,-900 90,752.5,900,0,3015,150,-900 90,941,150,0,3015,150,-900 90,1350,450,0,3015,150,-900 90,1412.5,750,0,3015,150,-900 90,1485,0,0,3015,150,-900 90,1697.5,300,0,3015,150,-900 90,1791,600,0,3015,150,-900 90,2074,900,0,3015,150,-900 90,2168,150,0,3015,150,-900 90,2546,750,0,3015,150,-900 90,2671,0,0,3015,150,-300,150,-450 90,2892,300,0,3015,150,-150,150,-600 *eldon, CADTutor Forum 2020 2 Quote
hugha Posted September 21, 2020 Posted September 21, 2020 Nice job Eldon, but AFAIK any comment should be preceded by a semi-colon, not an asterisk, viz: ;eldon, CADTutor Forum 2020 Hugh Adamson www.hatchKit.com.au Quote
eldon Posted September 21, 2020 Posted September 21, 2020 On 9/21/2020 at 7:22 AM, hugha said: Nice job Eldon, but AFAIK any comment should be preceded by a semi-colon, not an asterisk, viz: ;eldon, CADTutor Forum 2 Now that indeed is curious!! If I put a semicolon, then when I pick that hatch pattern file, I get an Error message. Quote
eldon Posted September 21, 2020 Posted September 21, 2020 (edited) Anyway, the asterisk was to populate the 'blank' line at the end so one does not have to put an extra blank line after the hatch information. Nothwithstanding advice from my elders and betters, I thought I would also write Wood Floor patterns for 100 units wide planks, 6 units wide planks and 4 units wide planks I hope they work. If not, pay attention to those who know! WoodFloor150.patFetching info... WoodFloor4.patFetching info... WoodFloor6.patFetching info... WoodFloor100.patFetching info... Edited September 21, 2020 by eldon 1 Quote
hugha Posted September 21, 2020 Posted September 21, 2020 Quote Now that indeed is curious!! If I put a semicolon, then when I pick that hatch pattern file, I get an Error message. Quote Anyway, the asterisk was to populate the 'blank' line at the end so one does not have to put an extra blank line after the hatch information. You add to global knowledge. Thank you. A blank line at the foot of a .PAT file has long been an accepted defense against that error message. What AutoCAD will accept from a .PAT file is quite arcane, for instance a blank line immediately following a *pattername,comment causes grief. Whatever works, but my own preference for comments is immediately preceding the whole pattern definition. Quote
