Veidere Posted September 11, 2020 Posted September 11, 2020 Hi. The surface has shifted away from the hight marks. Can the surface be moved in plase? Quote
Cad64 Posted September 11, 2020 Posted September 11, 2020 Can you provide some images so we can see what's happening? Quote
Cad64 Posted September 11, 2020 Posted September 11, 2020 I just realized you're using Civil3D. I have moved your question to the Civil3D section here: https://www.cadtutor.net/forum/forum/45-civil-3d-amp-ldd/ 1 Quote
CyberAngel Posted September 11, 2020 Posted September 11, 2020 See this page at the Autodesk Knowledge Network. Be very careful when moving surfaces. Make sure it's not the individual point that has shifted. Try to figure out what has happened so you're fixing the right problem. I once lost a job for fixing the wrong problem. 1 Quote
