tutorial for Igneus SHC in CAD
I need a tutorial for Igneus SHC in CAD.
Igneus SHC software has a plugin for CAD, I already installed it, but it doesn't say how to use it. I saw a little demo on YouTube of MJLM, and that's why I'm looking for it here. Hopefully you can help me.
Installation
The file igneus.lsp contains all the new CAD utilities provided. Copy this file to a folder on your computer in your CAD program's search path. For example, the CAD programs installation folder will work just fine (usually C:\program files\yourcadprogram or C:\program files\yourcadprogramscompany\yourcadprogram). Next, start your CAD program. At your CAD program's command prompt, type: (load "igneus.lsp")and press the ENTER key to load the Igneus Cad Utilities.
If this is the first time you have ever loaded the Igneus Cad Utilities, be sure to run the new command fpoptions. (See below for a description of all new commands.)
It says it right there ^^^ in the installation instructions.
fpoptions
Sets the options used by The Igneus Cad Utilities commands. Be sure to run this command first in order to set the utilities up for your drawing units, font, and layer preferences. When this command is done, the selected options are written to the file igneus.cfg and used as defaults every time igneus.lsp is loaded from then on.
Edited by ReMark
Remark the web site referred to a pdf for details,  I did not download have enough "stuff" as it is. Maybe post the pdf ?
The "details" are in the Read Me file.  Basically it is a verbal description of how to install and run the program followed by the available commands and what each accomplishes.
