When I right click it brings up the options menu, I want it to be either Repeat or open the copy / move menu. ?????
In your options menu there is a right click option under User preferences (In Autocad 2007 anyways). You can change it there or you can make your own up as seen here:
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-LT/files/GUID-38939586-0AE9-4C8D-A7C9-20B018361222-htm.html
More on the subject:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoCAD-Core/files/GUID-7C6AE349-DDF0-40DF-9D1E-FA9702BE88BB-htm.html
Edited by Berzerker
