savabgd Posted September 6, 2020 Posted September 6, 2020 How can i on easiest way allign text from multileader to line? I put example file to see what i want example.dwgFetching info... Quote
dtkell Posted September 10, 2020 Posted September 10, 2020 I would use the 'align' command. take 2 points on leader landing and align to object. then move to where you want text put arrowheads where needed Quote
rkent Posted September 10, 2020 Posted September 10, 2020 I like to rotate the UCS for an example like this, and I have a quick key of UO for UCS, OBject, select the object. Place the mleader, use the add leader for the other end. Finally I go back to UCS, World with another quick key, UW. 1 Quote
