Hello, in my tests I believe the ssget "_X" order the selectionset by the last entity insert on drawing
Ex:
If I insert a block name "A" 4 times at drawing:
1 - <Entity name: 1b8fdc375c0>
2 - <Entity name: 1b8fdc37650>
3-  <Entity name: 1b8fdc376e0>
4- <Entity name: 1b8fdc37770>
When I do (setq sel (ssget "_X" (list (cons 0  "INSERT") (cons 2 "A"))))
0-><Entity name: 1b8fdc37770>
1-><Entity name: 1b8fdc376e0>
2-><Entity name: 1b8fdc37650>
3-><Entity name: 1b8fdc375c0>
So, is possible update the order of the ssget "_X" in the drawing?
like for example I want to move the entity 3 to 1, when I do (setq sel (ssget "_X" (list (cons 0  "INSERT") (cons 2 "A")))): the result will:
1-><Entity name: 1b8fdc375c0>
2-><Entity name: 1b8fdc376e0>
3-><Entity name: 1b8fdc37650>
Very doubtful you can though do a sort on say XY position if looking for some sort of pattern.
Edited by BIGAL
Maybe perhaps something like this can help...
(defun reorderss ( / chkssX ss n m en em i e sss )
  (defun chkssX ( ss / i l )
    (if ss
        (setq l (cons (ssname ss (setq i (1- i))) l))
    l
  (if (setq ss (ssget "_X"))
      (setq n (getint (strcat "\nSpecify which nth element you want to move to some other position - it must be from 0 to " (itoa (1- (sslength ss))) " : ")))
      (setq m (getint (strcat "\nSpecify to which position you want to move nth element from 0 to " (itoa (1- (sslength ss))) " : ")))
      (if (/= n m)
          (setq en (ssname ss n))
          (setq em (ssname ss m))
          (setq sss (ssadd))
          (setq i -1)
          (while (< (setq i (1+ i)) (sslength ss))
            (setq e (ssname ss i))
            (cond
              ( (= i m)
                (ssadd en sss)
              ( (= i n)
                (ssadd em sss)
              ( t
                (ssadd e sss)
  (if sss
      (princ "\n")
      (princ (chkssX sss))
      sss
      (princ "\n")
      (princ (chkssX ss))
      ss
(defun chkssX ( / ss i l )
  l
Command: (chkssx)
(<Entity name: 1cbc5778d70> <Entity name: 1cbc5778d60> <Entity name: 1cbc5778d50> <Entity name: 1cbc5778d40>)
Command: (setq ss (reorderss))
Specify which nth element you want to move to some other position - it must be from 0 to 3 : 2
Specify to which position you want to move nth element from 0 to 3 : 1
(<Entity name: 1cbc5778d70> <Entity name: 1cbc5778d50> <Entity name: 1cbc5778d60> <Entity name: 1cbc5778d40>)<Selection set: 2c>
rog1n please explain more what it is your doing and why change order.
Marco nice answer sort of thing you put away for a problem another day.
Hi, I trying to make numbering automatic of blocks (like http://www.lee-mac.com/autolabelattributes.html)
but if I add a a new block between 3,4 the result will 1,2,3,7,4,5,6, so I want to know if possible update the block orders in my drawing to the numbering count 1,2,3,4,5,6,7
I tried to set a number with xdata to this new block 7 with number 3 for example, them I will have 1,2,3,4,5,6,7 but If I remove the number 1 for exemple the result will have 1,3,2,4,5,6
So I think the only solution is update the order of inserted the blocks on drawing, to be dynamic
Edited by rog1n
Maybe if you could show us , such Before.dwg and after.dwg , some better solution could  give you .
Hi... Me again. I've changed my code a little to suit better your needs... See if it has now some bigger meaning to you...
(defun reorderss ( filter / chkss ss n m en i e sss )
  (defun chkss ( ss / i l )
    (if ss
    l
  (if (setq ss (ssget "_X" filter))
      (initget 5)
      (initget 5)
      (if (/= n m)
          (setq sss (ssadd))
          (setq i -1)
            (cond
              ( (= i m)
                (ssadd en sss)
                (ssadd e sss)
              ( (eq e en)
                nil
              ( t
                (ssadd e sss)
  (if sss
      (princ "\n")
      (princ (chkss sss))
      sss
      (princ "\n")
      (princ (chkss ss))
      ss
(defun chkssX ( filter / ss i l )
  l
Command: (chkssx nil)
(<Entity name: 260f38ab5c0> <Entity name: 260f38ab5b0> <Entity name: 260f38ab5a0> <Entity name: 260f38ab590> <Entity name: 260f38ab580> <Entity name: 260f38ab570> <Entity name: 260f38ab560> <Entity name: 260f38ab550> <Entity name: 260f38ab540>)
Command: (setq ss (reorderss nil))
Specify which nth element you want to move to some other position - it must be from 0 to 8 : 7
Specify to which position you want to move nth element from 0 to 8 : 2
(<Entity name: 260f38ab5c0> <Entity name: 260f38ab5b0> <Entity name: 260f38ab550> <Entity name: 260f38ab5a0> <Entity name: 260f38ab590> <Entity name: 260f38ab580> <Entity name: 260f38ab570> <Entity name: 260f38ab560> <Entity name: 260f38ab540>)<Selection set: 13>
Edited by marko_ribar
Sounds like 3 options required.
If you want to say manually add a block between 3 & 4 then you could do it by imply a number searching the named blocks, then go through all the others,  greater than, renumbering adding 1. Then insert.
Adding a new block search blocks find last number +1 and insert.
Reorder blocks as per solution by Marko.
Thinking more a few options. I am sure some others will come up with a couple more.
Edited by BIGAL
The auto label routine referred to relies on the creation order of the block references. The only option I see is to recreate the blocks that should come after the new block. If you copy them in place be sure to pay attention to the selection order!
