Loidy Posted September 3, 2020 Share Posted September 3, 2020 Good Day, I would like to request an accessible files of autocad vba (userform/macro/.dvb/.frm). What I am trying to achieve is a toolbar that allows me to compute values and arrange it in a table per layers. Any files could do, related or not, finished or not, i'll try to get some ideas/codes/formats how its made, still learning some codes. As for example.. I draw many lines,polylines, area/region, volume on autocad with different LAYER name each. then i'll just drag select all the objects I want to compute, then give me result of the TOTAL LENGTH, TOTAL AREA, TOTAL VOLUME, TOTAL COUNT(separated function) showed in TABLE/listbox per LAYER, then later on i'll try to send it to EXCEL. LAYER | Length/Area/Volume/Count | UNITS Line1 | 100 | meters Liner2 | 100 | meters Area3 | 100 | sq.meters Volume4 | 100 | cu.meters Count5 | 100 | pieces I hope you guys could share some files/sites, I found some, but it has password and cannot preview the code. Thanks Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted September 3, 2020 Share Posted September 3, 2020 Hi @Loidy, what you are asking it's not so easy because, depending from type of Object found you can have thousand properties, so you should give us an sample drawing based upon that we can show you the main rules of searching an object and retrive properties, count, and so on by VBA. So please share with us a sample drawing this can help us to find the best solution for what your are requiring. For example objects are in Model Space or PaperSapce ? Which version of Autocad do you have available, recently some additional functionality had been added. Regards Quote Link to comment Share on other sites More sharing options...
Loidy Posted September 3, 2020 Author Share Posted September 3, 2020 Sorry, here's my sample.. ty REQUEST SAMPLE.dwg Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted September 3, 2020 Share Posted September 3, 2020 @Loidy, thank you for your drawing, just to clarify better: For example you indicate on linear table on LAYER1 12000, and it's correct, but inside the calculation, there is also a region which perimeter are 4000, and this is not considered as a line or polyline, in order to be shown on LINEAR TABLE OBJECT LIST, this a region on layer1. So you want to calculate al object type on the same layer correct ? Thank you. Quote Link to comment Share on other sites More sharing options...
Loidy Posted September 3, 2020 Author Share Posted September 3, 2020 @PeterPan9720, I'm sorry. I forgot to update the values. Yes, regardless of line type ( line, polyline, circle, rectangle, arc...) as long as it has length and same layer.. tnx Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 4, 2020 Share Posted September 4, 2020 Sent you something read my PM. For others just Google it should be out there Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted September 4, 2020 Share Posted September 4, 2020 Hi @Loidy here below a sample code, of course could be optimized, but could be a starting point Sub Layers_DATA() Dim LayName() As Variant Dim ObjectsName() As Variant Dim LayerSx As AcadLayers Dim LayerX As AcadLayer Dim MyObject As AcadEntity Set LayerSx = ThisDrawing.Layers Count = 1 Count1 = 1 For Each LayerX In LayerSx If LayerX.Name <> "0" And LayerX.Name <> "Defpoints" Then ReDim Preserve LayName(Count) LayName(Count) = LayerX.Name Count = Count + 1 For Each MyObject In ThisDrawing.ModelSpace If MyObject.Layer = LayerX.Name Then ReDim Preserve ObjectsName(Count1) ObjectsName(Count1) = MyObject.ObjectName Select Case ObjectsName(Count1) Case "AcDbPolyline" TotalLength = TotalLength + MyObject.Length Case "AcDbLine" TotalLength = TotalLength + MyObject.Length Case "AcDbRegion" TotalPerimeter = TotalPerimeter + MyObject.Perimeter TotalArea = TotalArea + MyObject.Area Case "AcDbCircle" TotalCirc = TotalCirc + MyObject.Circumference TotalDiam = TotalDiam + MyObject.Diameter Case "AcDb3dSolid" Debug.Print "PIPO" End Select Count1 = Count1 + 1 End If Next End If 'TRANSFER DATA TO EXCEL or to a TABLE and reset data and count for next layer TotalLength = 0 TotalPerimeter = 0 TotalArea = 0 TotalCirc = 0 TotalDiam = 0 Count1 = 0 Next End Sub I'm still working on it, due to I have poor experience with 3d objects managing and VBA, see section AcDb3dSolid. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 4, 2020 Share Posted September 4, 2020 (edited) Peterpan9720 Arc has length and radius, centroid. Circle centroid maybe add. Using the dumpit.lsp is good for finding the properties of an object, VBA version ? Something I am playing with non VBA gets desired properties via 1 line could be done in VBA using call subfunction. AcDb3dsolid maybe use Massprops. Can write a file and read it back. Pline props.lsp Edited September 4, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted September 5, 2020 Share Posted September 5, 2020 Hi @BIGAL, thank you for suggestion, I'll look forward. Bye Quote Link to comment Share on other sites More sharing options...
Loidy Posted September 24, 2020 Author Share Posted September 24, 2020 @PeterPan9720 thanks sir, but I'm still struggling how to use it using selectionset and how to put it in table. Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted September 24, 2020 Share Posted September 24, 2020 On 9/5/2020 at 1:10 AM, BIGAL said: Peterpan9720 Arc has length and radius, centroid. Circle centroid maybe add. Using the dumpit.lsp is good for finding the properties of an object, VBA version ? Something I am playing with non VBA gets desired properties via 1 line could be done in VBA using call subfunction. AcDb3dsolid maybe use Massprops. Can write a file and read it back. Pline props.lsp 3.62 kB · 0 downloads 6 hours ago, Loidy said: @PeterPan9720 thanks sir, but I'm still struggling how to use it using selectionset and how to put it in table. See Autodesk forum, https://forums.autodesk.com/t5/vba/vba-for-computing-total-length-area-volume-count-for-every/m-p/9727578 For last update. I'm still working, when I have time, I've some issue with 3D objects. Bye Quote Link to comment Share on other sites More sharing options...
