Hello,
I have been trying for the last few days to automate out a process but have found myself pretty stuck. The process now involves manually going in and looking at the properties of the polyline and copying over the length to a separate excel file and matching it to the block that it goes to. The blocks all have their locations recorded on a separate excel file.
The best lead that I have right now is that I can use Data Extraction to pull all of the poly line data at once.  However sadly the Data Extraction command cannot pull information of the vertexes of polylines. This is where i need help! I was thinking that I could get around this by assigning the location of the first vertex of the polyline's (the start point 's) X and Y coordinates to the hyperlink, which CAN be extracted with Data Extraction. With the X and Y coordinates I would be able to cross compare the X and Y coordinates with the one from the block and know which it is matched too. I am very new to using LISP and have attempted to write it myself with little success. I am not sure how to write in the Hyperlink just as a string rather than as an actual address. I would like to be able to select all of the polylines at once and have to command change all the hyperlinks at once.
Thanks in advance for the help, I am exited to get better at using LISP!
Leo
