Tutorial-How to display the area of an enclosed figure
Ellen Finkelstein's Blog
Suppose that you would like to insert a label that displays the area of an enclosed figure. While the AREA command can show you the area, it doesn’t create a label in your drawing. If you insert the area at the end of a leader, that area doesn’t change if your object changes in size.
You can use fields (introduced in AutoCAD 2006) to display information about objects. In this tutorial, you create a leader that displays the area of a tub. You can do this in model space or paper space.
  1. Set up a text style for your leader text and a dimension style for the leader.
  2. Start the MLEADER or QLEADER command.
  3. Specify the first leader points and subsequent points until you see a text cursor.
  4. If you’re using the QLEADER command, At the Specify text width <0″>: prompt, specify the endpoint of the text, leaving enough room for the expected text. At the Enter first line of annotation text <Mtext>: prompt, press Enter to open the Multiline Text Editor, as shown here.
Tips from our reader: To get rid of the text box gray hatch,  use Tools -> Options -> User Preferences and uncheck “Display background of fields” under “Fields”
  1. For either command, when you see the text cursor, type Area: and a space.
  2. Right-click in the text area and choose Insert Field.
  3. In the Field dialog box, choose Objects from the Field Category drop-down list. This makes the field you want easier to find.
  4. Choose Object in the Field Names box.
  5. In the Object Type area, click the Select Objects button.
  6. You return to your drawing, where you should select the object. The Field dialog box comes back and it should look like the one you see here.
Note: If your enclosed area isn’t one object, you may be able to use the BOUNDARY command to create a polyline. That’s what I did with the tub.
  1. Choose the property you want to display. I chose Area.
  2. Choose a format; I chose Architectural.
  3. Click OK.
  4. If necessary, adjust the width of the text by dragging on the edge of the Multiline Text Editor’s ruler.
  5. Click outside the editor to close it. Here you see the result.
Want more productivity tips like this? You can draw and edit faster and easier with this easy to follow top 25 productivity tips every AutoCAD user should know.
The post Tutorial-How to display the area of an enclosed figure appeared first on AutoCAD Tips Blog.
View the full article
