loudy000 Posted August 24, 2020 Share Posted August 24, 2020 Hi All, I have existing layers that i need to rename based from current layer property (line weight and color) example the new name would be: 0.50-alu-profile any help would be much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted August 24, 2020 Share Posted August 24, 2020 I don't see where the color fits in... (defun c:test ( / dmz ly lynm obj wgt) (setq dmz (getvar 'dimzin)) (setvar 'dimzin 0) (while (setq ly (tblnext "layer" (null ly))) (setq ly (cdr (assoc 2 ly)) obj (tblobjname "layer" ly) wgt (cdr (assoc 370 (entget obj))) lynm (strcat (rtos (* wgt 0.01) 2 2) "-" ly) ) (entmod (subst (cons 2 lynm) (assoc 2 (entget obj)) (entget obj) ) ) ) (setvar 'dimzin dmz) ) The above should do it (I think... because I don't know how in my computer the line weight reads 50 instead of 0.50, so I just divide by 100) 1 Quote Link to comment Share on other sites More sharing options...
loudy000 Posted August 24, 2020 Author Share Posted August 24, 2020 38 minutes ago, Jonathan Handojo said: I don't see where the color fits in... (defun c:test ( / dmz ly lynm obj wgt) (setq dmz (getvar 'dimzin)) (setvar 'dimzin 0) (while (setq ly (tblnext "layer" (null ly))) (setq ly (cdr (assoc 2 ly)) obj (tblobjname "layer" ly) wgt (cdr (assoc 370 (entget obj))) lynm (strcat (rtos (* wgt 0.01) 2 2) "-" ly) ) (entmod (subst (cons 2 lynm) (assoc 2 (entget obj)) (entget obj) ) ) ) (setvar 'dimzin dmz) ) The above should do it (I think... because I don't know how in my computer the line weight reads 50 instead of 0.50, so I just divide by 100) Thank you very much! Quote Link to comment Share on other sites More sharing options...
loudy000 Posted August 24, 2020 Author Share Posted August 24, 2020 Hi @Jonathan Handojo Sorry how do i modify this to get also the line pattern/ line style? Thanks. Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted August 24, 2020 Share Posted August 24, 2020 @loudy000 Like this? (defun c:test ( / dmz ly lynm obj pat wgt) (setq dmz (getvar 'dimzin)) (setvar 'dimzin 0) (while (setq ly (tblnext "layer" (null ly))) (setq ly (cdr (assoc 2 ly)) obj (tblobjname "layer" ly) wgt (cdr (assoc 370 (entget obj))) pat (cdr (assoc 6 (entget obj))) lynm (strcat (rtos (* wgt 0.01) 2 2) "-" pat "-" ly) ) (entmod (subst (cons 2 lynm) (assoc 2 (entget obj)) (entget obj) ) ) ) (setvar 'dimzin dmz) ) 1 Quote Link to comment Share on other sites More sharing options...
loudy000 Posted August 24, 2020 Author Share Posted August 24, 2020 Thank you @Jonathan Handojo Quote Link to comment Share on other sites More sharing options...
