Gregmw Posted August 22, 2020 Posted August 22, 2020 Hi i want to draw a rectangular building that is 10000 mm x 5000 mm I have opened an A3 template with a scale of 100:1 when I draw the lines they are full size and don’t go anywhere in fitting within the A3 sheet template sorry about the basic question - and I am sure I am just doing something wrong with the scale Quote
steven-g Posted August 22, 2020 Posted August 22, 2020 Should that be 1:100 If that doesn't fix the problem then please post the dwg file so we can see. 1 Quote
eldon Posted August 22, 2020 Posted August 22, 2020 Have you checked that the template that you are using is a metric one? Have you checked what the plotting units are? A full sized A3 sheet in landscape orientation is 420mm by 297mm, and at 1 to 100, that would be equivalent to 42000mm by 29700mm. Ample room for your 10000mm by 5000mm building. 1 Quote
