PASISI GODSAVE Posted August 19, 2020 Posted August 19, 2020 HOW TO CONVERT A CIRCLE TO A POLYLINE Quote
rkmcswain Posted August 20, 2020 Posted August 20, 2020 One way would be to run the POLYGON command, set the number of sides to a high number like 500, then draw this on top of the existing circle, then erase the circle. This could be automated with autolisp if you were doing many of these. Something like this (quick and dirty, no error checking) (defun c:foo ( / CEN I K RAD SSET W ) (vl-cmdf "._layer" "_m" "polylines" "_c" "40" "polylines" "") (setq sset (ssget "_X" '((0 . "CIRCLE"))) i 0) (repeat (sslength sset) (setq k (ssname sset i)) (setq w (entget k)) (setq rad (cdr (assoc 40 w))) (setq cen (cdr (assoc 10 w))) (vl-cmdf "._polygon" "500" cen "_C" rad) (entdel k) (setq i (1+ i)) ) ) 1 Quote
CyberAngel Posted August 20, 2020 Posted August 20, 2020 You can't convert a circle to a one-segment arc polyline (I've tried), but you can convert two arc segments. Draw two semicircles or break a circle in two places. Convert one to a pline (or edit if PEDIACCEPT is on) and join the other. Quote
Dana W Posted August 20, 2020 Posted August 20, 2020 (edited) I draw the circle, then start the polyline command, type A (for arc) and trace over the circle with two automatically joined arcs, then erase the circle after aligning the arcs to the circle, then CLOSE the polyline arc object. At least this gives you a non-faceted line. I am sure there is a way to automate this as well, but the difficult part would be getting the arcs to follow the circle since one cannot give the polyline arcs a radius before or while drawing them. The other thing is that I don't write or care about code any longer so it is up to someone else to do that. Sometimes AutoCad will recognize that you are tracing an object, and sometimes it won't. I never did find a control for that one/ The only reason I have found to make a circle out of polyline arcs is because one cannot edit a circle as easily as one can a polyline. You cannot change a circle's width, for instance. Edited August 20, 2020 by Dana W Quote
Cad64 Posted August 20, 2020 Posted August 20, 2020 I use this lisp routine, courtesy of Kent Cooper. ;; CirclePolylineSwap.lsp [command names: C2P & P2C] ;; Two commands, to convert in both directions between a Circle and a circular ;; (two-equal-arc-segment closed) Polyline, such as the Donut command makes. ;; Both commands: ;; 1. ask User to select again if they miss, pick an incorrect object type, or pick an ;; object on a locked Layer; ;; 2. remove selected/converted object, but can easily be edited to retain it; ;; 3. account for different Coordinate Systems; ;; 4. retain non-default/non-Bylayer color, linetype, linetype scale, lineweight, ;; and/or thickness. ;; See additional notes above each command's definition. ;; Kent Cooper, May 2011 ;; C2P ;; To convert a selected Circle to a two-equal-arc-segment closed zero- ;; width Polyline circle [Donut w/ equal inside & outside diameters], ;; which can then be modified as desired [given width, etc.], since Pedit ;; will not accept selection of a Circle. ; (defun C:C2P (/ *error* cmde csel cir cdata cctr crad cextdir pdata) (vl-load-com) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ); end if (command "_.undo" "_end") (setvar 'cmdecho cmde) ); end defun - *error* (setq cmde (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "_.undo" "_begin") (prompt "\nTo convert a Circle to its Polyline equivalent,") (while (not (and (setq csel (ssget ":S" '((0 . "CIRCLE")))) (= (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 (entget (ssname csel 0))))))) 0) ; 0 for Unlocked, 4 for Locked ); end and ); end not (prompt "\nNothing selected, or not a Circle, or on a Locked Layer.") ); end while (setq cir (ssname csel 0); Circle entity name cdata (entget cir); entity data cctr (cdr (assoc 10 cdata)); center point, OCS for Circle & LWPolyline w/ WCS 0,0,0 as origin crad (cdr (assoc 40 cdata)); radius cextdir (assoc 210 cdata); extrusion direction ); end setq (setq pdata (vl-remove-if-not '(lambda (x) (member (car x) '(67 410 8 62 6 48 370 39))) cdata) ; start Polyline entity data list -- remove Circle-specific entries from ; Circle's entity data, and extrusion direction; 62 Color, 6 Linetype, 48 ; LTScale, 370 LWeight, 39 Thickness present only if not default/bylayer pdata (append ; add Polyline-specific entries '((0 . "LWPOLYLINE") (100 . "AcDbEntity")) pdata ; remaining non-entity-type-specific entries '((100 . "AcDbPolyline") (90 . 2) (70 . 129) (43 . 0.0)) ; 90 = # of vertices, 70 1 bit = closed 128 bit = ltype gen. on, 43 = global width (list (cons 38 (caddr cctr)); elevation in OCS above WCS origin [Z of Circle center] (cons 10 (list (- (car cctr) crad) (cadr cctr))); vertex 1 '(40 . 0.0) '(41 . 0.0) '(42 . 1); 0 width, semi-circle bulge factors (cons 10 (list (+ (car cctr) crad) (cadr cctr))); vertex 2 '(40 . 0.0) '(41 . 0.0) '(42 . 1) cextdir ; extr. dir. at end [if in middle, reverts to (210 0.0 0.0 1.0) in (entmake)] ); end list ); end append & pdata ); end setq (entmake pdata) (entdel cir); [remove or comment out this line to retain selected Circle] (command "_.undo" "_end") (setvar 'cmdecho cmde) (command "_.pedit" (entlast) "w" pause "") (princ) ); end defun ;; P2C ;; To convert a selected closed two-equal-arc-segment global-width circular ;; Polyline [Donut] to a true Circle. If selected Polyline has non-zero global ;; width, offers User option to draw Circle along center-line or along inside or ;; outside edge of width, and retains choice as default for next use. ;; Works on both old-style "heavy" and newer "lightweight" Polylines. ;; [Will not work on one with more than two segments, or with two unequal- ;; included-angle segments, even if truly circular.] ; (defun C:P2C (/ *error* cmde psel pl pdata pwidadj cposdef cpostemp pv1 pv2 cdata) (vl-load-com) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ); end if (command "_.undo" "_end") (setvar 'cmdecho cmde) ); end defun - *error* (setq cmde (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "_.undo" "_begin") (prompt "\nTo convert a Polyline circle to a true Circle,") (while (not (and (setq psel (ssget ":S" '((0 . "*POLYLINE")))) (if psel (setq pl (ssname psel 0) pdata (entget pl))) (= (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 pdata))))) 0) ; 0 for Unlocked, 4 for Locked (if (= (cdr (assoc 0 pdata)) "POLYLINE"); "heavy" Polyline (progn; then (command "_.convertpoly" "_light" pl ""); retains same entity name (setq pdata (entget pl)); replace "heavy" Polyline entity data ); end progn T; else - to not return nil for LWPolyline ); end if (member '(90 . 2) pdata); two vertices (member '(42 . 1.0) (cdr (member '(42 . 1.0) pdata))); two half-circle bulge factors ; needs to be really precise -- will be for one made with Donut, ; but may not be for one made with, for example, Pline [pt] Arc ; Direction [direction] [halfway around] Close, even with Snap on ); end and ); end not (prompt "\nNothing selected, or not a circular Polyline [Donut], or on a Locked Layer.") ); end while (if (and (assoc 43 pdata) (/= (cdr (assoc 43 pdata)) 0)); global non-zero width (progn; then (initget "Center Inside Outside") (setq pwidadj (/ (cdr (assoc 43 pdata)) 2) cposdef (cond (_P2Ccpos_) (T "Center")); Center default on first use cpostemp (getkword (strcat "\nCircle position on Donut [Center/Inside/Outside] <" (substr cposdef 1 1) ">: " ); end strcat ); end getkword & cpostemp _P2Ccpos_ (cond (cpostemp) (cposdef)) ); end setq ); end progn (setq pwidadj 0); else ); end if (setq pv1 (cdr (assoc 10 pdata)); = Polyline Vertex 1 [XY] pv2 (cdr (assoc 10 (cdr (member (assoc 10 pdata) pdata)))); = Polyline Vertex 2 [XY] ; can't use parameter XYZ WCS locations, because cdata needs XY OCS locations cdata (vl-remove-if-not '(lambda (x) (member (car x) '(67 410 8 62 6 48 370 39))) pdata) ; build circle entity data list -- remove Polyline-specific entries from ; Polyline's entity data, and extrusion direction; 62 Color, 6 Linetype, 48 ; LTScale, 370 LWeight, 39 Thickness present only if not default/bylayer cdata (append ; add circle-specific entries '((0 . "CIRCLE") (100 . "AcDbEntity")) cdata ; remaining non-entity-type-specific entries (list '(100 . "AcDbCircle") (list 10 ; center (/ (+ (car pv1) (car pv2)) 2); X = halfway between X's of vertices (/ (+ (cadr pv1) (cadr pv2)) 2); Y = halfway between Y's of vertices (cdr (assoc 38 pdata))); Z of Circle = elevation of Pline (cons 40 ; radius (+ (/ (distance; diameter -- needs 3D points for 3D distance (vlax-curve-getStartPoint pl) (vlax-curve-getPointAtParam pl 1) ); end distance 2 ); end / (cond ((= _P2Ccpos_ "Inside") (- pwidadj)) ((= _P2Ccpos_ "Outside") pwidadj) (T 0); Pline with width & Center option, or no width/no position prompt ); end cond ); end + ); end cons (assoc 210 pdata); extr. dir. at end [if in middle, reverts to (210 0.0 0.0 1.0) in (entmake)] ); end list ); end append & cdata ); end setq (entmake cdata) (entdel pl) ; [remove or comment out above line to retain selected ; Polyline -- will be left lightweight if originally heavy] (command "_.undo" "_end") (setvar 'cmdecho cmde) (princ) ); end defun (prompt "\nType C2P to convert a Circle to its Polyline equivalent.") (prompt "\nType P2C to convert a circular Polyline to its Circle equivalent.") 1 Quote
eldon Posted August 20, 2020 Posted August 20, 2020 If one was to use the POLYGON command, you would only have to draw a three sided polygon, inscribed in the required sized circle, then curve Fit it. Quote
RetroCAD Posted August 21, 2020 Posted August 21, 2020 On 8/20/2020 at 11:03 AM, eldon said: If one was to use the POLYGON command, you would only have to draw a three sided polygon, inscribed in the required sized circle, then curve Fit it. This is how it's done. I usually draw a square and fit that, but yeah triangle Quote
SLW210 Posted August 24, 2020 Posted August 24, 2020 If you want to convert a Circle to a Polyline, you need a LISP or other program. AFAIK, no AutoCAD command for that, you can break the circle, then PEDIT and Close is as close as you can get with AutoCAD. Everything else is How to DRAW/REDRAW circles as Polylines. So, that brings us to, How many circles do you need to convert/redraw as Polylines? And, Why do you need them Polylines? You can also draw circle Polylines with ELLIPSE, with PELLIPSE=1. To use DONUT, use same diameter for Inside and Outside. Quote
acadesign09 Posted August 25, 2020 Posted August 25, 2020 There is no way to convert a circle to a polyline object. Note: Draw your object in polyline everytime you begin a plan Quote
Dahzee Posted August 25, 2020 Posted August 25, 2020 Excuse my ignorance, but why would you need to do this? My interest is definitely piqued, as I can't think why this would be more useful than a circle. Feel free to tell me to mind my own business :-) Quote
steven-g Posted August 25, 2020 Posted August 25, 2020 I can't speak for the OP's reason, but a lot of CNC software will only accept polylines. Quote
SLW210 Posted August 26, 2020 Posted August 26, 2020 Most CNC software actually does the converting, at least the different ones I have used in the past and even then they are arcs and lines, no polylines. But, that's why I asked How Many and Why. It may be there is another way to get the end result. Quote
