selected text change into current text style & height
akgbmb
Dear
I am looking for suitable lisp for selected text property change as below
(1) text size change into current text height
(2) text style change into current text style
select texts are may be single line text or mtext
pls support
Try this
(defun c:t2c (/ ss sty tht cnt obj)
  (setq ss (ssget ":L" '((0 . "*TEXT"))))
  (cond (ss
          (setq sty (getvar 'textstyle) tht (getvar 'textsize))
          (repeat (setq cnt (sslength ss))
            (setq obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))))
            (mapcar '(lambda (x y) (vlax-put obj x y)) (list 'stylename 'height) (list sty tht))
          );end_repeat
  );end_cond
);end_defun
This will not override any formatted mtext and will use the current textstyle and textsize as defined by the system variables of the same name.
