vorno Posted August 10, 2020 Posted August 10, 2020 Hi everyone, Long-time user of the forum, but first-time poster. Thank you all over the years for your various contributions, they have helped me a lot over the last ~8years! My problem: I have ~15km of road where I need to calculate the width of the existing road every 10m, using a survey consisting of polylines. I then need to take this information and put it into a table (Excel for example). So far I've found a lisp routine that creates dimensions between two objects at a given interval, but I don't know how to get the information into Excel. Furthermore, it would be highly beneficial for me to identify the location of the measurements in Excel (whether identified by a simple sequential number or by x/y data). I look forward to this discussion! Thank you in advance, Vaughan. Quote
devitg Posted August 10, 2020 Posted August 10, 2020 Quote For better understanding, and to get further help, please upload such sample.dwg Expand Quote
BIGAL Posted August 11, 2020 Posted August 11, 2020 I posted an answer over at forums/autodesk maybe ? getpointatdist, getclosestpointto Quote
vorno Posted August 11, 2020 Author Posted August 11, 2020 Hi everyone, Thank you. The solution was for me to create a C3D corridor set to every 10m, using the edge of pavement polylines as the extents of my corridor. In order to do this I had to create a dummy-surface using cogo points around the extents and then a surface profile. I then used a C3D report to export the findings and from there I was able to copy the report into Excel and format the data so that the combined widths were isolated. Quote
