ezra Posted August 2, 2020 Posted August 2, 2020 I want to add the Modify toolbar to my User Interface. Someone here please give me the sequence to drag the tool bar out to my UI. Nothing I do will allow me to get it out of the panel. Ezra Quote
Cad64 Posted August 2, 2020 Posted August 2, 2020 It's been a long time since I've used toolbars, and I see you're using 2005LT, but try this. At the command prompt, type -TOOLBAR Make sure to include the dash. Then type the name of the toolbar, which in your case would be MODIFY. Then type SHOW. The Modify toolbar should now appear somewhere in your UI. 1 Quote
BIGAL Posted August 3, 2020 Posted August 3, 2020 Are you saying your trying to make a custom toolbar that is say two toolbars combined ? I have custom toolbars that have bits pulled out of all sorts of other toolbars but they were created by adding 1 line at a time. Quote
ezra Posted August 3, 2020 Author Posted August 3, 2020 Thank you Cad64, unfortunately it did not work. BIGAL no I am not trying to make a custom toolbar, I simply want to be able to drag the modify toolbar onto my UI from the panel. Thank you both anyway, Ezra 1 Quote
Cad64 Posted August 3, 2020 Posted August 3, 2020 Take a look at this knowledge network article. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Adding-a-specific-toolbar-a-workspace.html If none of the options in that article work then maybe the toolbar is already open but hidden behind a palette or something? You may need to move things around to find it. Quote
steven-g Posted August 3, 2020 Posted August 3, 2020 It would help if you posted a screenshot to make sure we are all thinking about the same thing? Show us what you are calling the 'modify' toolbar Quote
ezra Posted August 3, 2020 Author Posted August 3, 2020 Cad64: You have my humble apologies, your suggestion does in fact work, In my extreme dumbness I forgot to add the dash to TOOLBAR. Ezra 1 Quote
Cad64 Posted August 4, 2020 Posted August 4, 2020 16 hours ago, ezra said: Cad64: You have my humble apologies, your suggestion does in fact work, In my extreme dumbness I forgot to add the dash to TOOLBAR. Glad to hear it's working now. 1 Quote
