I want to add the Modify toolbar to my User Interface.
Someone here please give me the sequence to drag the tool bar out to my UI.
Nothing I do will allow me to get it out of the panel.
Ezra
It's been a long time since I've used toolbars, and I see you're using 2005LT, but try this.
At the command prompt, type  -TOOLBAR  Make sure to include the dash.
Then type the name of the toolbar, which in your case would be MODIFY.
Then type SHOW.
The Modify toolbar should now appear somewhere in your UI.
Are you saying your trying to make a custom toolbar that is say two toolbars combined ?  I have custom toolbars that have bits pulled out of all sorts of other toolbars but they were created by adding 1 line at a time.
Thank you Cad64, unfortunately it did not work.  BIGAL  no I am not trying to make a custom toolbar, I simply want to be able to drag the
modify toolbar onto my UI from the panel.
Thank you both anyway,
Ezra
  • Confused 1
It would help if you posted a screenshot to make sure we are all thinking about the same thing? Show us what you are calling the 'modify' toolbar
Cad64:
You have my humble apologies, your suggestion does in fact work, In my extreme dumbness I forgot to add the dash to TOOLBAR.
Ezra
  • Thanks 1
  On 8/3/2020 at 10:05 PM, ezra said:
Cad64:
Expand
:lol: Glad to hear it's working now.
