Ssyntaxis to add subroutines from a self developed Lisp program
Hello everyone,
I developed a routine that updates blocks from a specific folder on the server as follows:
Command: UBV
Update selected blocks or all of them? [Selection/All/Name]:
I want to specify a name for many drawings for all to update the same block.
I know I can run the command like this:
(c:UBV)
But I want to add the subroutines
"N" (for the name variable)
"BlockName" (for the block name)
Since this is a command that I developed, I cannot run it like this:
(command
  "UBV"
  "n"
  "BlocknName"
Because it is not an AutoCAD command. My question is:
Can I run a self developed command (c:UBV) adding subroutines?
  My first guess was something like but it didin't work.
(C:UBV "n" "BlockName")
What would be the syntaxis to add subroutines from a self developed Lisp program?
Thanks in advance
You basically don't. That's why other programmers such as our legend Lee Mac do something like this: Outline Objects
Notice he created another function (LM:outline) that accepts an argument. In your case, you'd want to build a function that accepts 2 arguments, and then call the function. He then created the function (c:outline) and in that, he call the function LM:outline.
I do use LM:outline too for other purposes and because LM:outline returns a selection set, I can then use it to do other stuff with it on other functions.
The purpose of this is so that you can do something like what you're encountering now and gives more flexibility for users to modify any variables to suit their needs:
(defun ubv (arg1 arg2 / )
    ;; your codes
    ;; Better have your function return something so that you can use the return values for something else outside it.
(defun c:ubv nil (ubv "n" "Block Name"))
(defun c:ubv2 nil (ubv "n2" "Block Name 2"))
(defun c:ubvp nil (ubv (getstring t "\nSpecify name for drawing: ") (getstring t "\nSpecify block name: ")))
;; and so on
Edited by Jonathan Handojo
(defun c:ubv1 ( / )
  (vl-load-com)
  (vla-sendcommand
    (vla-get-activedocument
      (vlax-get-acad-object)
    "UBV n BlockName "
  • Thanks 1
On 7/24/2020 at 10:26 PM, Stefan BMR said:
(defun c:ubv1 ( / )
  (vl-load-com)
  (vla-sendcommand
    "UBV n BlockName "
Wonderful Stefan. Thanks a lot. There is always who has an answer.
