Is there a way for a lisp to go through the entire drawing (without selection) and delete vertical lines from within the block without (those rev clouded in dwg attached)? I have many of these throughout the paper space (multiple tabs) but I did not want to the position of the leader to change - stay where it is and how it is (ONLY that line to be removed). or better yet to make it layer defpoints and colour 30.
so basically this vertical line is extended with the addition in the number of lines but I resorted to a simple Qleader and would like the existing projects (that already have the old block) to match the new leader that has no vertical line.
Is there anyone who could give me hand here?
Thanks,
Sam
new block.dwgFetching info...
Try this:
(defun c:foo (/ c)
  ;; RJP » 2020-07-22
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= 0 (vlax-get b 'islayout) (vlax-get b 'isxref))
      (vlax-for	a b
	(and (or (and (= "AcDbPolyline" (vla-get-objectname a))
		      (equal (car (setq c (vlax-get a 'coordinates))) (caddr c) 1e-8)
		 (and (= "AcDbLine" (vla-get-objectname a))
		      (equal (car (vlax-get a 'startpoint)) (car (vlax-get a 'endpoint)) 1e-8)
	     (entmod (append (entget (vlax-vla-object->ename a)) '((8 . "defpoints") (62 . 30))))
(vl-load-com)
  On 7/22/2020 at 8:18 PM, ronjonp said:
Try this:
(defun c:foo (/ c)
  ;; RJP » 2020-07-22
      (vlax-for	a b
(vl-load-com)
Expand
Good day @ronjonp,
I did not even come close to what you created but had some similar result whereby all vertical lines on other blocks are now defpoints and #30 - the reason is because I still have a hard time dealing with "dxflist" I believe it is called!
If I were to include these blocks exclusively:
"Tx - Leader avec texte 238 - 11x17"
"Tx - Leader avec texte 165 - 8½x14"
"Tx - Leader avec texte 165 - 8½x11"
Would you let me know how to use a list of block names/ items?
Thanks
Expand
Try something like this:
(defun _foo (blocknames / c)
  ;; RJP » 2020-07-23
    (if	;; (= 0 (vlax-get b 'islayout) (vlax-get b 'isxref))
	(vl-position (strcase (vla-get-name b)) (mapcar 'strcase blocknames))
      (vlax-for	a b
(vl-load-com)
(_foo '("Tx - Leader avec texte 238 - 11x17"
Edited by ronjonp
Thanks a lot @ronjonp
The only difference between your earlier code and this one is that I now need to physically open the block in block editor for the changes to take effect - whereas on your previous version a simple "regen" would have taken care of the issue.
Would you please let me know if there is a way to get around that?
Other than that, it is great and working beautifully!
The changes are not showing up in the other blocks because they are dynamic and modified. This makes the name different ie *U#. The code above modifies the block definition and not the block references.
So to overcome this, I have to open the block in block editor?
Thanks
