“AJMAL” is my function
I need shortcut “AJ”
So I will put “defun c:aj()”
But I need shortcut also full also, how I will set the “defun”
(“aj” and “ajmal” also)
Expand
(defun C:aj ()
(c:ajmal)
  On 7/20/2020 at 1:16 PM, mstb said:
(defun C:aj ()
(c:ajmal)
Expand
this is creating a another function
i need only 2 command for same function
Try it ... two commands same code called?
(defun c:ajmal nil (alert "AJMAL!") (princ))
(defun c:aj nil (c:ajmal))
If you type aj the autocorrect will display ajmal but you must pick.
I had a defun "c:goto" but my fingers always typed "goot: so I added that as well like ronjonp 2 defuns.
