hosyn Posted July 26, 2020 Author Posted July 26, 2020 (edited) Now I was about checking it again Edited July 26, 2020 by hosyn Quote
dlanorh Posted July 26, 2020 Posted July 26, 2020 Assuming (setq block-list '(("A-old" . 1) ("B-old" . 1) ("C-old" . 1) ("D-old" . 1) ("E-old" . 1) ("F-old" . 1) ("G-old" . 1) ("H-old" . 1))) (setq compare-list '((rgt "A-old" "A-new") (rgt "C-old" "C-new") (rgt "K-old" "K-new") (rgt "E-old" "E-new") (rgt "D-old" "D-new") (rgt "H-old" "H-new"))) Then the inelegant (mapcar '(lambda (x) (cons (cadr (assoc (car x) (mapcar 'cdr compare-list))) (cdr x))) (vl-remove-if-not '(lambda (x) (vl-position (car x) (mapcar 'cadr compare-list))) block-list)) produces the desired result 1 Quote
hosyn Posted July 26, 2020 Author Posted July 26, 2020 20 minutes ago, Jonathan Handojo said: I'm not quite sure what you mean though. The function I wrote above should return the desired result Dear Jonathan Handojo Your code in example checked and its pretty good , but one issue in my data at the compare list there are space like that (rgt "PP" "PT SOCKET IP 54") These space can be conflict and mismatch running ? Quote
hosyn Posted July 26, 2020 Author Posted July 26, 2020 Thank you to both Jonathan Handojo and dlanorh Your codes do best, thank you for helping guys Quote
hosyn Posted July 26, 2020 Author Posted July 26, 2020 Hi and in continue (vl-...) function how should modified (setq compare-list '((rgt "A-old" "A-new") (rgt "C-old" "C-new") (rgt "K-old" "K-new") (rgt "E-old" "E-new") (rgt "D-old" "D-new") (rgt "H-old" "H-new"))) if blk-name be "c-old" give us "c-new" if blk-name be "k-old" give us "k-new" and ...... if blk-name theres not in compare-list give us nil So many thanks Thanks for any cooperating Quote
