(defun c:?? (/ *error* os a d p1 p2 p % lst)
;hp 14.07.2020
  (defun *error* (msg)
    (ai_sysvar nil)
    (terpri)
    (princ msg)
  (ai_sysvar '(( "OSNAPZ" . 0) ( "OSMODE" . 522)))
  (while (and (setq p1 (getpoint "\nSpecify point.. "))
              (setq p2 (getpoint p1 "\nNext point.. "))
    (setq lst (list p1 p2)
          lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst)
          a (apply 'angle lst)
          d (apply 'distance lst)
    (not (zerop d))
    (setq % (/ (caddr (mapcar '- p2 p1)) d))
    (if (minusp %)
      (mapcar 'set '(p1 p2) (reverse lst))
      lst
    (setq p (trans (apply 'mapcar (cons '(lambda (a b) (* 0.5 (+ a b))) lst))1 0))
    (entmakex (list '(0 . "TEXT") (cons 1 (strcat (if (minusp %) "\U+2192 " "\U+2190 ")))
                    (cons 40 (* d 0.1)) (cons 10 p) (cons 11 p) (cons 50 a) '(72 . 0) '(73 . 2)
  (ai_sysvar nil)
p/s: text style use TTF  (eg: Arial, calibri etc..) not SHX
;hp 14.07.2020
    (ai_sysvar nil)
    (terpri)
    (princ msg)
    (not (zerop d))
    (if (minusp %)
      lst
  (ai_sysvar nil)
this gives me a question mark every time....
Expand
missing font type
p/s: text style use TTF  (eg: Arial, Calibri etc..) not SHX
check your Text Style as mentioned
  On 7/14/2020 at 2:47 PM, hanhphuc said:
missing font type
now I only have an arrow, my bad for the text style. I was not attentive.
I've seen a similar question and this code by LRM solved my problem! thanks for that!
;; Determine the maximum slope of a 3dface.
;; 7/13/2020
(defun c:FaceSlope (/ ss en edata p1 p2 p3 v1 sv a slope midpt s endpt)
  (setq oldsnap (getvar "osmode"))
  (setvar "osmode" 0)
  (princ "\nPlease select 3DFACE and press ENTER.")
  (setq	ss    (ssget)
	en    (ssname ss 0)
	edata (entget en)
  (setvar "cmdecho" 0)
  (if (= (cdr (assoc 0 edata)) "3DFACE")
      (setq p1 (cdr (assoc 10 edata))	;set p1, p2, p3 to the three vertices of the 3DFACE
	    p2 (cdr (assoc 11 edata))
	    p3 (cdr (assoc 12 edata))
      (if (or (equal p1 p2 0.0001)
	      (equal p1 p3 0.0001)
	      (equal p3 p2 0.0001)
	(princ "\nThe first 3 vertices of the face are not unique.")
	  (setq normal (cross (mapcar '- p2 p1) (mapcar '- p3 p1)))
	  (setq v1 (cross '(0.0 0.0 1.0) normal))
	  (setq sv (cross v1 normal))
	  (setq a (distance '(0 0 0) sv))
	  (setq sv (mapcar '/ sv (list a a a)))
	  (setq a (expt (+ (expt (car sv) 2) (expt (cadr sv) 2)) 0.5))
	  ;; check if a = 0
	  (if (< (abs a) 0.00001)
	    (setq slope "Vertical")
	    (setq slope (/ (caddr sv) a))
	  (princ "\nThe slope is: ")
	  (princ slope)
	  (princ "\nThe slope vector is: ")
	  (princ sv)
	  (setq midpt (mapcar '/ (mapcar '+ p1 p2 p3) '(3.0 3.0 3.0)))
	  (setq
	    s (/ (+ (distance p1 p2) (distance p2 p3) (distance p1 p3)) 3.0)
	  (setq endpt (mapcar '+ midpt (mapcar '* sv (list s s s))))
	  (command "_line" midpt endpt "")
	  ;; draw line showing maximum slope
	  (setq slope (LM:roundto slope 3))
	  (command "text" midpt "" "" slope "")
	)				; end if false, no duplicates
      )					;end true, is face
    )					; end if duplicate
       (princ "\nSelected object must be a face.")
 )					; end if face
  (setvar "osmode" oldsnap)
  (setvar "cmdecho" 1)
;;; Compute the cross product of 2 vectors a and b
(defun cross (a b / crs)
  (setq	crs (list
	      (- (* (nth 1 a) (nth 2 b))
