Hi,
I want to List specific existing layer names for viewport freeze.
The layer names always start with "29-barge-*"
The * is a sequenced number starting at 1.
How do I do that?
Thanx, but then I would not post my topic on the Lisp forum
Not sure where this thread is going but are you familiar with layer property filters?
If you really must use a LISP code,
(defun ListLayerByPattern (pat / ly nm rtn)
    (while (setq ly (tblnext "layer" (null ly)))
	(if (wcmatch (setq nm (cdr (assoc 2 ly))) pat)
	    (setq rtn (cons nm rtn))
    (reverse rtn)
so you can call it like:
(ListLayerByPattern "29`-barge`-[1-9]*")
Or apply a function to every matching layer
;; pat - matching pattern by layer name
;; fnc - function accepting one argument that represents the layer name
(defun ApplyToLayerByPattern (pat fnc / ly nm)
	    (eval (list fnc nm))
For example, this one freezes all layers of the matching pattern except for the current layer:
(defun c:test ( / cur lys)
    (setq lys (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) cur (getvar 'clayer))
    (ApplyToLayerByPattern "29`-barge`-[1-9]*"
	'(lambda (x)
	     (and
		 (not (wcmatch cur "29`-barge`-[1-9]*"))
		 (vla-put-Freeze (vla-item lys x) :vlax-true)
That is how I'd do it too, and the same suggestion which I made, but later deleted as the OP seemed disinterested in an analog approach.   :beer:
Another analog approach might be to include such layer names, pre-viewport frozen, and Grouped into a filter in the Layer Properties Manager in your customized default QNEW template.
Old school.   :playing:
Looks like @Jonathan Handojo has gotten it sorted out though, cool.    :beer:
    (reverse rtn)
	'(lambda (x)
	     (and
Nice solution man, thanx!
I guess the ` in (ListLayerByPattern "29`-barge`-[1-9]*") is an escape character for the dash?
The [1-9] numbers (layers) are ascending (not infinite) in number during steps in my main routine.
And I actually only want to VP freeze the last 2 numbers (layers 8 and 9 in your example):
number 9 in the Viewport on the last Layout number and number 8 in the Viewport of the second to last Layout number.
My layout names have numbers like 01, 02, etc. and are also ascending in number
I list those Viewports with:
(setq vport_1 (ssget "x" (list (cons 0 "VIEWPORT") (cons 410 (nth 0 (reverse (layoutlist)))))))
(setq vport_2 (ssget "x" (list (cons 0 "VIEWPORT") (cons 410 (nth 1 (reverse (layoutlist)))))))
