hopefully you can read the red text on the picture as it explains what i'm looking for...if not, let me know and I'll type it out again. thank you
Red text against a black background is never easy to read.
Expand
image.thumb.png.407386b9ea3afff0c57fc22e5c9531d4.png:)
Edited by ronjonp
Here is an example note layout names include "Model" it numbers based on layout order as this can be different to just get layout names. Use the (vla-get-count tabs) for the number of layouts - 1.
(defun c:1rev ( / len doc lay plotabs newstr tabname oldtagn ss1 att x y)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq tabs (vla-get-Layouts doc))
(setq y 0)
(setq bname "DA1DRTXT")
(setq oldtagn "REV_NO")
(setq newstr (-(getint "Please enter version for sheets..") 1))
(repeat (vla-get-count tabs)
(vlax-for lay tabs
(setq x (vla-get-taborder lay))
(setq tabname (vla-get-name lay))
(if (and (= y x) (/= tabname "Model"))
      (setvar "ctab" tabname)
      (setq ss1 (ssget "x"  (list (cons 0 "INSERT") (cons 2 bname)(cons 410 tabname))))
      (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 0 )) 'getattributes)
        (if (= oldtagn (strcase (vla-get-tagstring att)))
           (vla-put-textstring att (rtos (setq newstr (+ newstr 1)) 2 0))
(setq y (+ y 1))
(c:1rev)
Edited by BIGAL
