Ajmal Posted June 29, 2020 Posted June 29, 2020 (edited) How can I add a filter in ssget...? Actually, I want to select only unlocked line with cross selection. is it possible with this": L" (setq lines (ssget "_C" p1 p2 (list (cons 0 "LINE")))) like this (ssget "_+.:S:E:L" '((0 . "ARC,CIRCLE,ELLIPSE,LINE"))) this is not getting how. can i add can someone help (ssget "_+.c:L" '((0 . "ARC,CIRCLE,ELLIPSE,LINE"))) i want to edit this lisp (setq p1 (getpoint "\nSelect object...")) (setq p2 (getcorner p1)) (setq mp (polar p1 (angle p1 p2) (/ (distance p1 p2) 2))) (setq p1 (list (nth 0 p1) (nth 1 p1))) (setq p2 (list (nth 0 p2) (nth 1 p2))) (setq lines (ssget "_C" p1 p2 (list (cons 0 "LINE")))) (if (/= (sslength lines) 4) (alert "4 lines need to be selected") Edited June 29, 2020 by Ajmal Quote
Hippe013 Posted June 29, 2020 Posted June 29, 2020 Lee Mac has a great website for explaining the ssget filters. Here is the link. http://www.lee-mac.com/ssget.html Quote
dlanorh Posted June 29, 2020 Posted June 29, 2020 Try this (if (not (equal '(nil nil) (sssetfirst nil (ssget "_C" p1 p2 '((0 . "LINE")))))) (setq lines (ssget "_:L"))) Quote
Ajmal Posted June 29, 2020 Author Posted June 29, 2020 On 6/29/2020 at 2:06 PM, dlanorh said: Try this (if (not (equal '(nil nil) (sssetfirst nil (ssget "_C" p1 p2 '((0 . "LINE")))))) (setq lines (ssget "_:L"))) Expand this is working. thanks. Quote
