Reference: AutoCAD 2016; Windows 10 Enterprise
Hello CAD Folks,
I have a drawing with text in model space and viewport setup of that drawing in paper space. In the layer manager, I changed the bylayer color of the text (not override color). When I observe the text through the viewport, the text bylayer color shows the same – as if I had not changed anything. Come to find out, when I click inside the viewport and enter the Regen command, the changed bylayer color appears! This should not be necessary. Is there a setting that needs to be applied? Or, could this be related to a compromising system in my computer?
OPTIONS > SYSTEM tab.
Select the item in the green box shown in the attached image.
My advice is not to do it though.  REGEN is a hog and will take more time to change layouts.  How much more time depends on what kind of hot rod video processor system you have.
I personally am more than happy with REGEN on demand.
  • Like 2
Rather than switching  to Model Space then back to Paper Space the REGENALL command regenerates the entire drawing and refreshes all viewports. REA is the default command alias.
@Dana W.
Yup! That did it. Thanks friend...😀
