hosneyalaa Posted June 25, 2020 Posted June 25, 2020 Sorry English is not good Hello all If possible, help If he has the following list (setq lst-pt '((2.91097 7.9291) (15.2064 6.99916) (12.7764 1.72037) (0.268183 0.311625))) Depending on the location of the item (reverseLITP lst-pt 2) ((2.91097 7.9291) (15.2064 6.99916) (0.268183 0.311625) (12.7764 1.72037)) OR (reverseLITP lst-pt 1) ((2.91097 7.9291) (0.268183 0.311625) (12.7764 1.72037) (15.2064 6.99916)) Thanks, thanks ALL Quote
Tharwat Posted June 25, 2020 Posted June 25, 2020 Here is one way. (defun reverse:list (lst pos / lft run new lft out) (and (< pos (length lst)) (setq lft lst run -1 ) (repeat pos (setq new (cons (nth (setq run (1+ run)) lst) new) lft (cdr lft) ) ) (setq out (append (reverse new) (reverse lft))) ) out ) 1 Quote
dlanorh Posted June 25, 2020 Posted June 25, 2020 45 minutes ago, hosneyalaa said: Sorry English is not good Hello all If possible, help If he has the following list (setq lst-pt '((2.91097 7.9291) (15.2064 6.99916) (12.7764 1.72037) (0.268183 0.311625))) Depending on the location of the item (reverseLITP lst-pt 2) ((2.91097 7.9291) (15.2064 6.99916) (0.268183 0.311625) (12.7764 1.72037)) OR (reverseLITP lst-pt 1) ((2.91097 7.9291) (0.268183 0.311625) (12.7764 1.72037) (15.2064 6.99916)) Thanks, thanks ALL Try this (defun revlstp (lst p / nlst) (repeat p (setq nlst (cons (car lst) nlst) lst (cdr lst))) (reverse (append lst nlst)) ) 1 Quote
hanhphuc Posted June 25, 2020 Posted June 25, 2020 (edited) Nice Tharwat & dlnorh (defun foo (i l / n k) (setq n (length l)) (cond ((not i)(reverse l)) ((< i n) (repeat (1+ i) (setq k (cons (car l) k) l (cdr l) ) ) (apply 'append (mapcar 'reverse (list k l))) ) (t nil) ) ) this reverse (1+ nth) (setq lst '(1 2 3 4 5 6 7)) (foo nil lst) ;(7 6 5 4 3 2 1) (foo 0 lst) ;(1 7 6 5 4 3 2) (foo 3 lst) ;(1 2 3 4 7 6 5) (foo 6 lst) ;(1 2 3 4 5 6 7) (foo 7 lst) ; nil (defun revnth (n lst) ;hp 25.06.2020 ((lambda (f n l) (reverse (append (f (- (length lst) n) (reverse lst)) (f n lst)))) (list '(n l) '(if (> n 0) (cons (nth (1- n) l) (f (1- n) l)))) n l ) ) reverse at nth (setq lst '( 1 2 3 4 5 6 7 8 9 10 ) ) (revnth 0 lst) ; (10 9 8 7 6 5 4 3 2 1 0 ) (revnth 2 lst) ; (0 1 10 9 8 7 6 5 4 3 2 ) Edited June 25, 2020 by hanhphuc add revnth 1 Quote
hosneyalaa Posted June 25, 2020 Author Posted June 25, 2020 Thanks @Tharwat and @dlanorh and @ hanhphuc Sorry for my late reply The lisps were shown working great and I think beautiful thanks ALL 1 2 Quote
pBe Posted June 25, 2020 Posted June 25, 2020 Another (defun _relist (lst n) ((lambda (i / l m) (while (and (< i n) (setq v (Car lst))) (setq l (cons v l) i (1+ i) lst (cdr lst)) ) (append (reverse l) (reverse lst)) ) 0 ) ) @ hanhphuc You just have to go the other way than the rest of us don't you.. < n before l st > (defun revnth (n lst)... (defun foo (i l / n k)... 1 Quote
hanhphuc Posted June 26, 2020 Posted June 26, 2020 4 hours ago, pBe said: @ hanhphuc You just have to go the other way than the rest of us don't you.. < n before l st > i didn't notice it, it's a habit putting list after n perhaps subconsciousness like cons apply mapcar vl-remove etc.. 1 Quote
hosneyalaa Posted June 27, 2020 Author Posted June 27, 2020 On 6/25/2020 at 11:18 PM, pBe said: Another (defun _relist (lst n) ((lambda (i / l m) (while (and (< i n) (setq v (Car lst))) (setq l (cons v l) i (1+ i) lst (cdr lst)) ) (append (reverse l) (reverse lst)) ) 0 ) ) @ hanhphuc You just have to go the other way than the rest of us don't you.. < n before l st > (defun revnth (n lst)... (defun foo (i l / n k)... Thanks @pBe Quote
