Hi all, I have a function to check if a string is hex or not in vba, can someone change or rewrite the function in autolisp?
Public Function IsHex(strInput As String) As Boolean
  Dim i As Long
  IsHex = False
  If Len(strInput) = 0 Then Exit Function
  For i = 1 To Len(strInput)
    If Not (Mid$(strInput, i, 1) Like "[0-9a-hA-H]") Then Exit Function
  Next
  IsHex = True
End Function
(defun is-hex-p (str)
  (wcmatch str "~*[~0-9a-fA-F]*")
Edited by Roy_043
Fixed hex range
H is not valid hex...
Edited by Lee Mac
Neither is G... Thanks. Fixed.
