rog1n Posted June 20, 2020 Share Posted June 20, 2020 Hello, I have a list with sublist, how I add a new item to a sublist if the first element is equal to a variable: Ex: lst = (("2" "b") ("1" "a")) x="2" y="c" result: (("2" "b" "c") ("1" "a")) but if the variable not exist on the list will create a new sublist like: lst = (("2" "b") ("1" "a")) x="3" y="c" result: (("2" "b" ) ("1" "a")("3" "c")) below a code I trying to do this... (setq found nil index 0) (if lst (progn (While (and (setq f (nth index lst)) (not found)) (if (= (car f) x) (progn (setq found t) ;I dont know how add the value to sublist I think is simple with mapcar ) ) (setq index (1+ index)) ) (if (not found) (setq lst (cons (cons x (list y)) lst))) ) (setq lst (list (list x y))) ) ) Quote Link to comment Share on other sites More sharing options...
pBe Posted June 20, 2020 Share Posted June 20, 2020 3 hours ago, rog1n said: Hello, I have a list with sublist, how I add a new item to a sublist if the first element is equal to a variable: .... sample source (setq ls '(("2" "b") ("1" "a")("2" "c")("3" "c")("1" "c")("2" "a"))) ( (lambda (lst / x y) (foreach itm ls (setq x (Car itm)) (setq y (cadr itm)) (princ (Strcat "\nX = " x )) (princ (Strcat "\nY = " y )) (princ "\n========" ) ;;; This section ;;; (setq lst (if (setq f (assoc x lst)) (subst (cons x (cons y (cdr f))) f lst) (cons (list x y) lst) ) ) ;;; This section ;;; ) ) nil ) X = 2 Y = b ======== X = 1 Y = a ======== X = 2 Y = c ======== X = 3 Y = c ======== X = 1 Y = c ======== X = 2 Y = a ======== (("3" "c") ("1" "c" "a") ("2" "a" "c" "b")) <-- end result You may have to do some kind of sorting either on the end result or on the source. HTH 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 20, 2020 Share Posted June 20, 2020 assoc & subst are the key functions here - similar to how you might manipulate the DXF data returned by entget. You are working with an association list wherein the first element of each sublist represents a key, and the tail of the list represents the data associated with that key. You can use assoc to test whether a sublist with a given key exists, and then use subst to substitute the sublist with a modified version within the main list. For example - say you start with the following list: _$ (setq lst '(("2" "b") ("1" "a"))) (("2" "b") ("1" "a")) And you have the following new values: _$ (setq key "2" val "c") You can test whether the key exists using assoc: _$ (setq old (assoc key lst)) ("2" "b") Since it does, you can modify it using the value returned by assoc: _$ (setq new (append old (list val))) ("2" "b" "c") And finally, you can substitute it into the main list using subst: _$ (setq lst (subst new old lst)) (("2" "b" "c") ("1" "a")) If the key does not exist, you can use cons to push it onto the list: _$ (setq key "3" val "c") _$ (assoc key lst) nil _$ (setq lst (cons (list key val) lst)) (("3" "c") ("2" "b" "c") ("1" "a")) Putting this all together with an if statement to branch accordingly, we can write a function such as the following: (defun addtolist ( key val lst / old ) (if (setq old (assoc key lst)) (subst (append old (list val)) old lst) (cons (list key val) lst) ) ) _$ (setq lst '(("2" "b") ("1" "a"))) (("2" "b") ("1" "a")) _$ (setq lst (addtolist "2" "c" lst)) (("2" "b" "c") ("1" "a")) _$ (setq lst (addtolist "3" "d" lst)) (("3" "d") ("2" "b" "c") ("1" "a")) 1 1 1 Quote Link to comment Share on other sites More sharing options...
pBe Posted June 21, 2020 Share Posted June 21, 2020 22 hours ago, Lee Mac said: assoc & subst are the key functions here -... For example - say you start with the following list:ist:... .. Putting this all together with an if statement to branch accordingly, we can write a function such as the following: Pandemic or not Lee, you always have time to write a thorough explanation of things 1 Quote Link to comment Share on other sites More sharing options...
rog1n Posted June 21, 2020 Author Share Posted June 21, 2020 Thank you, @pBeand @Lee Mac after see the code of Lee Mac it is so simple and easy to do but I stuck at this for hours Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 21, 2020 Share Posted June 21, 2020 Thank you both, I'm glad it helps. Quote Link to comment Share on other sites More sharing options...
