Sheep Posted June 19, 2020 Share Posted June 19, 2020 Hello all. Hope everybody doing fine during Covid19. I tried using Getreal but but got an error "Requires numeric value." For example: 123 <space> df. I want to seperate it so i can use it later. Tried using CAR and CADR to get the number and text. Any idea without using VLX. Thanks Quote Link to comment Share on other sites More sharing options...
pBe Posted June 19, 2020 Share Posted June 19, 2020 You want an input that includes a space character? (setq val (getstring T "\nEnter Value :")) (setq p (vl-string-position 32 val)) (setq number (substr val 1 p )) (Setq therest (substr val (+ 2 p))) If you want the variable number to be a real number use (distof number) Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 19, 2020 Author Share Posted June 19, 2020 1 hour ago, pBe said: You want an input that includes a space character? Thank you for your reply. Actually i want to remove the space and get the number and text. For example, i want to enter a distance (numbers) and notes (text) in one line. 123<space>df. The number will get its own Setq and same for the text. Is it possible to do it without VLX? Quote Link to comment Share on other sites More sharing options...
pBe Posted June 19, 2020 Share Posted June 19, 2020 4 minutes ago, Sheep said: Thank you for your reply. Actually i want to remove the space and get the number and text. For example, i want to enter a distance (numbers) and notes (text) in one line. 123<space>df. The number will get its own Setq and same for the text. Is it possible to do it without VLX? Sheep That is exactly what i posted, Let me put it in a way you can use on command prompt (defun c:demo (/ val p number text) (setq val (getstring T "\nEnter Value :")) (setq p (vl-string-position 32 val)) (setq number (substr val 1 p)) (Setq text (substr val (+ 2 p))) (princ (strcat "\nVariable number: " number)) (princ (strcat "\nVariable text: " text)) (princ) ) Unless without VLX means something else entirely, then i'm fresh out of ideas 1 Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 19, 2020 Author Share Posted June 19, 2020 OK, thanks. I'll try it later. What is vl-string-position? Quote Link to comment Share on other sites More sharing options...
pBe Posted June 19, 2020 Share Posted June 19, 2020 vl-string-position (AutoLISP) <-- link 1 ascii (AutoLISP) < --- link 2 vl-string-search (AutoLISP) < --- link 3 Quote What is vl-string-position? The functions return value is an integer representing the displacement at which char-code was found from the beginning of the string [ refer to link #1 ], in this case (vl-string-position 32 "123 df") = 3 Where in this string is the character " " located with this string value ? "123 df" Quote "But why 32?" Because the vl-string-position is using a numeric value representation of the character to be searched. [ refer to link #1 ][[ refer to link #2] You can however use another function which will give you the same result. (Vl-string-search " " "123 df") = 3 Quote "Why would you use first one and not the other" Thats the first thing that pop into my head, force of habit, I dont know. But serioulsy vl-string-position is reportedly faster than vl-string-search. There's also: (setq str "123 df") (vl-position 32 (VL-STRING->LIST str)) = 3 (vl-string-mismatch (itoa (atoi str)) str) = 3 ( (lambda (n s / a ) (while (not (eq (setq a (substr s 1 1)) " ")) (setq s (substr s 2) n (1+ n))) ) 0 str ) An why am I posting all this? I have nothing else better to do today 1 Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 19, 2020 Author Share Posted June 19, 2020 2 minutes ago, pBe said: An why am I posting all this? I have nothing else better to do today To be honest, this is the most complete answer i got. I don't mind if someone give out the keyword and i'll search it later but this....just great. Thank you for your time. A great leader always explain so other can follow. Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 19, 2020 Author Share Posted June 19, 2020 One more thing, should i use the vl-load-com if i use vl-string-position? Quote Link to comment Share on other sites More sharing options...
pBe Posted June 19, 2020 Share Posted June 19, 2020 Yes, better have it and not need than need and not have. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 19, 2020 Share Posted June 19, 2020 4 hours ago, Sheep said: For example: 123 <space> df. I want to seperate it so i can use it later. Tried using CAR and CADR to get the number and text. car & cadr ? hint: (setq str "123 DF" lst (read (strcat "(" str ")" )) ) (print (cadr lst)) $0.02 (defun c:tt ( / lst ) (or (and (setq lst (read (strcat "(" (getstring t "\nInput value : ") ")"))) ;evaluate as LIST (mapcar ''( (a b) (princ (strcat "\n" a (vl-princ-to-string b)))) '( "Number : " "Text : ") lst ) ) (princ "\nNull input?") ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
pBe Posted June 19, 2020 Share Posted June 19, 2020 1 minute ago, hanhphuc said: (read (strcat "(" (getstring t "\nInput value : ") ")"))) ... (strcat "\n" a (vl-princ-to-string b)))) '( "Number : " "Text : ") .. Yeah, that too. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 19, 2020 Share Posted June 19, 2020 My $0.05 no Vl you can do a repeat and look at each character in a string, Strlen, (substr str x 1) using strcat to join together once a space is found its numb then continue to end of string to get text part. Its probably the slowest way. Do this way for MAC no VL. Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 22, 2020 Author Share Posted June 22, 2020 (edited) On 6/19/2020 at 2:56 PM, pBe said: Sheep That is exactly what i posted, Let me put it in a way you can use on command prompt (defun c:demo (/ val p number text) (setq val (getstring T "\nEnter Value :")) (setq p (vl-string-position 32 val)) (setq number (substr val 1 p)) (Setq text (substr val (+ 2 p))) (princ (strcat "\nVariable number: " number)) (princ (strcat "\nVariable text: " text)) (princ) ) Unless without VLX means something else entirely, then i'm fresh out of ideas Hi again. I tried you sample and when i didn't enter the text, it wil give out numberp:nil. Maybe i didn't give out the full requirement sorry. The distance is a MUST but the text not all the time. Example : 123 dx 123 1234 df 1234 Can i use IF (= nil) for the text? I hope my English can give you an idea. Edited June 22, 2020 by Sheep Quote Link to comment Share on other sites More sharing options...
pBe Posted June 22, 2020 Share Posted June 22, 2020 1 hour ago, Sheep said: Can i use IF (= nil) for the text?.. Yes,. very good, that is the general idea, include a condtional function (Setq text (if p (substr val (+ 2 p)))) That will result to nil, then when the time to use the text variable (if text ... do something) or (Setq text (if p (substr val (+ 2 p)) "")) '<-- leave text variable as blank (Setq text (if p (substr val (+ 2 p)) "Not included)) '<-- or use a defualt value That way, when you include the text variable in a statement. it will still have a value and theres no need for a test (princ (strcat "\nPart number: " number "\nDescription: " text)) and so... (defun c:demo (/ val p number text) (setq val (getstring T "\nEnter Value :")) (setq p (vl-string-position 32 val)) (setq number (substr val 1 p)) (Setq text (if p (substr val (+ 2 p)) "Not Included")) (princ (strcat "\nPart number: " number "\nDescription: " text)) (princ) ) Command: DEMO Enter Value :123 dx Part number: 123 Description: dx Command: DEMO Enter Value :123 Part number: 123 Description: Not Included Command: DEMO Enter Value :1234 df Part number: 1234 Description: df Command: DEMO Enter Value :1234 Part number: 1234 Description: Not Included HTH 1 Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 23, 2020 Author Share Posted June 23, 2020 (edited) On 6/19/2020 at 4:03 PM, hanhphuc said: (defun c:tt ( / lst ) (or (and (setq lst (read (strcat "(" (getstring t "\nInput value : ") ")"))) ;evaluate as LIST (mapcar ''( (a b) (princ (strcat "\n" a (vl-princ-to-string b)))) '( "Number : " "Text : ") lst ) ) (princ "\nNull input?") ) (princ) ) By using your example i can extract the list (lst) using (nth 0 lst) and (nth 1 lst). Now i dont have to worry about the space thanks @hanhphuc. Edited June 23, 2020 by Sheep Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 23, 2020 Share Posted June 23, 2020 22 minutes ago, Sheep said: By using your example i can extract the list (lst) using (nth 0 lst) and (nth 1 lst). please be careful, LIST = 'space delimited' "123 DF ABC" --> ("123" "DF" "ABC") ; 3 items in list suggestion, underscore "_" or dash "-" "123 DF_ABC" -> ("123" "DF_ABC") ; 2 items in list 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 24, 2020 Share Posted June 24, 2020 (edited) For this "123 DF ABC" go back to maybe substr as soon as a space its not a number then whatever is left is a string. "123 DF ABC don't forget efg" (123 "DF ABC don't forget efg") ;convert number atof etc "123 DF ABC don't forget efg 54" (123 "DF ABC don't forget efg 54") Edited June 24, 2020 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 24, 2020 Share Posted June 24, 2020 (edited) 8 hours ago, BIGAL said: For this "123 DF ABC" go back to maybe substr as soon as a space its not a number then whatever is left is a string. "123 DF ABC don't forget efg" yes, agree dealing with STRING, preferable eg: substr, strlen, vl-string- functions etc.. eval list hiccups = strcase all capital & blank ignored (defun c:tt (/ lst n $) (or (and (setq lst (read (strcat "(" (getstring t "\nInput value : ") ")"))) (setq n (length lst)) (mapcar '(lambda (a b) (setq $ (vl-princ-to-string b)) (princ (strcat "\n" a (cond ((and (listp b) (> n 2)) (substr $ 2 (- (strlen $) 2))) (t $) ) ) ) ) '( "Number : " "Text : ") (if (> n 2) (list (car lst) (cdr lst)) lst) ) ) (princ "\nNull input?") ) (princ) ) command: TT Input value : 123 df abc Number : 123 Text : DF ABC Edited June 24, 2020 by hanhphuc duplicate vl-princ 1 Quote Link to comment Share on other sites More sharing options...
Sheep Posted June 30, 2020 Author Share Posted June 30, 2020 (edited) Hi all, Just hit another roadblock with autolisp. How to i convert those numbers into a coordinate (list?) X,Y,z(0). Example: 123 (- UserInput aPLow) 456 (i make a CADR from a GETPOINT) 0 (z value stay at 0) I want to get (123 456 0) so i can create a line at that point. Tried (setq xyzCombo (list Text1 (cadr aPLow) 0 )) Whenever i run the lisp, my Acad will stop running. Edited June 30, 2020 by Sheep Added an image. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 30, 2020 Share Posted June 30, 2020 (edited) I think your trying to hard just use my multi getvals get X Y Z much simpler. (setq lst (list x y z)) Or just use X,Y,Z this is already done Lee-mac => ( X Y Z) Edited June 30, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
