eldon Posted June 16, 2020 Share Posted June 16, 2020 (edited) Making a Pattern file A pattern file is a text file, which has a few simple rules. If it is to be a standalone file, then the first line of the file must be *(File-name)(,pattern description if needed). The file name cannot have any spaces, but for clarity it can have underscores. The second and subsequent lines are the description of the lines that form the hatch pattern, and follow the data format shown in the diagram. The angle, coords and dimensions can be taken from the working drawing. The length of a data line is limited to 80 characters. There must be a blank line, without any data, at the end of the file. A stand alone file has to be stored in a folder which is pathed for AutoCAD, so it is available in the Custom patterns. It can also be put in the main pattern file ACAD.PAT or ACADISO.PAT but that is trickier when you are trying to write the pattern. My procedure was to start a text editor with the pattern file loaded, and also start AutoCAD, then one can hatch, write a line into the pattern file and save it, and then (having erased the first hatch) hatch again. AutoCAD always takes the most recent pattern file so one sees whether the last line is doing what it should. I thought a few pictures would explain everything, but if I should have taken shortcuts, please seek further clarification. I have also added my whole hatch pattern file. *Quilt,satin quilt pattern 0,-2.25,0,0,15.36396103,4.5,-3.18198052 0,1.59099026,1.59099026,0,15.36396103,4.5,-3.18198052 0,1.59099026,-1.59099026,0,15.36396103,4.5,-3.18198052 0,5.43198052,3.18198052,0,15.36396103,4.5,-10.86396104 0,5.43198052,-3.18198052,0,15.36396103,4.5,-10.86396104 0,1.59099026,3.84099026,0,15.36396103,2.25,-7.68198052,2.25,-3.18198052 0,1.59099026,-3.84099026,0,15.36396103,2.25,-7.68198052,2.25,-3.18198052 0,3.18198052,5.43198052,0,15.36396103,2.25,-4.5,2.25,-6.36396103 0,3.18198052,-5.43198052,0,15.36396103,2.25,-4.5,2.25,-6.36396103 0,0,-7.68198052,0,15.36396103 45,-1.59099,-1.59099,-10.86396,10.86396,4.5,-3.18198,2.25,-6.36396,2.25,-3.18198 45,0,2.25,-10.86396,10.86396,4.5,-9.54594,4.5,-3.18198 45,2.25,0,-10.86396,10.86396,4.5,-9.54594,4.5,-3.18198 45,6.09099,1.59099,-10.86396,10.86396,10.86396,-10.86396 45,1.59099,6.09099,-10.86396,10.86396,10.86396,-10.86396 45,3.84099,-1.59099,-10.86396,10.86396,2.25,-14.04594,2.25,-3.18198 45,-1.59099,3.84099,-10.86396,10.86396,2.25,-14.04594,2.25,-3.18198 45,-1.59099,-9.27298,-10.86396,10.86396,4.5,-6.36396,4.5,-6.36396 90,0,-2.25,0,15.36396103,4.5,-3.18198052 90,-1.59099026,1.59099026,0,15.36396103,4.5,-3.18198052 90,1.59099026,1.59099026,0,15.36396103,4.5,-3.18198052 90,-3.18198052,5.43198052,0,15.36396103,4.5,-10.86396104 90,3.18198052,5.43098052,0,15.36396103,4.5,-10.86396104 90,-3.82099026,1.59099026,0,15.36396103,2.25,-7.68198052,2.25,-3.18198052 90,3.84099026,1.59099026,0,15.36396103,2.25,-7.68198052,2.25,-3.18198052 90,-5.43098052,3.18198052,0,15.36396103,2.25,-4.5,2.25,-6.36396103 90,5.43198052,3.18198052,0,15.36396103,2.25,-4.5,2.25,-6.36396103 90,7.68098052,0,0,15.36396103 135,1.59099,-1.59099,-10.86396,10.86396,4.5,-3.18198,2.25,-6.36396,2.25,-3.18198 135,-2.25,0,-10.86396,10.86396,4.5,-9.54594,4.5,-3.18198 135,0,2.25,-10.86396,10.86396,4.5,-9.54594,4.5,-3.18198 135,-1.59099,6.09099,-10.86396,10.86396,10.86396,-10.86396 135,-6.09099,1.59099,-10.86396,10.86396,10.86396,-10.86396 135,1.59099,3.84099,-10.86396,10.86396,2.25,-14.04594,2.25,-3.18198 135,-3.84099,-1.59099,-10.86396,10.86396,2.25,-14.04594,2.25,-3.18198 135,9.27298,-1.59099,-10.86396,10.86396,4.5,-6.36396,4.5,-6.36396 Edited June 24, 2020 by eldon Formatting!! Can't get rid of duplicate last picture 2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 16, 2020 Share Posted June 16, 2020 A pity Autodesk did not show that image with the abcd…. in its help, it makes a lot of sense and reveals very simply how it is put together will give it a try. Must admit my hard copy help manual is Release 12. Will have another go for convert a pline to a hatch. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 17, 2020 Share Posted June 17, 2020 Outstanding eldon, thanks for doing that. No time to check it out yet, but looking forward to doing so. Quote Link to comment Share on other sites More sharing options...
kirby Posted June 22, 2020 Share Posted June 22, 2020 Excellent description, thanks very much for taking the time to do this. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 26, 2020 Share Posted June 26, 2020 Found this in my travels. An updated Autodesk page. Quote Link to comment Share on other sites More sharing options...
